Home > Forums > Software User Forums > FLOW-3D
I want to simulate a Wave in the flume
Old   January 2, 2011, 07:01
Default I want to simulate a Wave in the flume
mahdi
mfeizbahr is on a distinguished road
I want to simulate a Wave in the flume..
how should I define boundary conditions ?
I mean in which direction should I define Flow?
mfeizbahr is offline   Reply With Quote
Old   January 17, 2011, 01:39
michael barkhudarov
MuxaB is on a distinguished road
wave are always defined at the x or y mesh boundaries, i.e., vertical boundaries. Designate a mesh boundary a wave boundary, set the initial fluid volume in the domain using fluid height, use the same height at the wave boundary, set the wave length and amplitude - and you are good to go.
MuxaB is offline   Reply With Quote
Old   January 17, 2011, 04:27
mahdi
Tnx a lot for help..
but.. what do u mean by : " wave are always defined at the x or y mesh boundaries .. "
you mean there is no mesh need for Z direction ?
Old   January 19, 2011, 00:45
michael barkhudarov
No, mesh should be defined in all three directions. What I meant is that in FLOW-3D surface wave generators are implemented as mesh boundary conditions and can be applied at any of the four mesh boundaries, xmin, xmax, ymin or ymax.
Old   January 19, 2011, 05:20
mahdi
thank you for informations.
fortunately after all I simulated the wave but there is another problem I faced, is the water dept decrease gradually .
I chose X min ( LW ) but really i don't know what should I choose for X max ?
in case of " continuative " the water dept decreased gradually.
in case of " Symmetry " water turn back after it reach to the end of mesh.
can u help me with that ?
i need no decrease in water dept and continuant wave for example like a seaside.
Old   January 19, 2011, 09:38
Stefano
stefmascio is on a distinguished road
choose the "Outflow" b.c. with the option "Allow fluid to enter...".
stefmascio is offline   Reply With Quote
Old   January 20, 2011, 03:55
mahdi
thank you Stefmascio...
but there is still dept decreasing..
Old   January 21, 2011, 23:50
mahdi
Dear Stefmascio...
When I did your suggestion for choosing the "Allow fluid to enter...” after running simulation the water dept start decreasing gradually and suddenly after 20 sec, new stream started coming into the flume with reverse direction, interfacing the waves and the incoming fluid cause an overtopping the water depth…
so this suggestion might not be a proper solution....
do u have any other idea ?
Old   January 22, 2011, 20:43
bejewel
bejewel is on a distinguished road
Model Setup\ Numerics\Wave boundary conditioon
then to choose:
Eliminate net volume flux at wave boundary,or
Include net volume flux at wave boundary.
good luck!
bejewel is offline   Reply With Quote
Old   January 23, 2011, 02:08
mahdi
Dear Bejewel ...
there is no " wave boundary condition " in Numerics ....
and really I could not fined any of your suggestions there....
thank you any way
Old   January 24, 2011, 04:58
Armen A. Ghirghidov
Ghirghidov is on a distinguished road
Dear mahdi,
Try to change mesh resolution.
Regards.
Ghirghidov is offline   Reply With Quote
Old   January 25, 2011, 10:04
bejewel
Flow-3D 9.4---> " wave boundary condition " in Numerics
Outlet boundary condition for wave flume with interFoam solver Arnoldinho OpenFOAM 9 July 10, 2018 05:15
How to simulate a sea wave striking a ship antenna Freeman FLUENT 0 February 25, 2009 14:17
to simulate shock wave propagation with turbulence cfdgeek Main CFD Forum 1 August 31, 2008 16:47
simulate propagating wave Gian, S. Main CFD Forum 0 October 27, 2006 03:11
how to simulate wave? dingding CFX 3 July 18, 2001 11:20
