Home > Forums > Software User Forums > FLOW-3D
cylindrical mesh
Old   October 10, 2011, 06:58
Default cylindrical mesh
Marcin
m.malysza is on a distinguished road
Why when using cylindrical mesh there is a plane 1 and 2, so the contact is from 0 - 360 degrees. I have uploaded two pictures demonstrating the problem. And my Q is how to eliminate this line.
1.
http://imageshack.us/photo/my-images/255/27918353.jpg/
2.
http://imageshack.us/photo/my-images/607/33350229.jpg/
BSR
m.malysza is offline   Reply With Quote
Old   November 21, 2011, 06:46
Unhappy
Giacomo Vi
master77 is on a distinguished road
I have the same problem. The grid seems to be not perfectly closed on 0-360°. The computation is affected by giving results not accectable in my case. Does anyone know how to guarantee a perfect closure of the cylindrical mesh? Thx Giacomo
master77 is offline   Reply With Quote
Old   November 30, 2011, 13:44
Jeff Burnham
JBurnham is on a distinguished road
See the question and answer about periodic boundaries.
JBurnham is offline   Reply With Quote
Old   September 11, 2013, 03:07
saeedtk is on a distinguished road
is this problem solved? plz help
saeedtk is offline   Reply With Quote
Old   September 11, 2013, 11:45
Jeff Burnham
There's not a problem. In cylindrical coords, like in Cartesian, there are always six boundary conditions per mesh block. The boundaries don't close up. Instead, you set the y-boundaries to 'periodic'. Whatever fluid, scalars, particles, etc. cross out of one y-boundary appear at the same elevation at the opposite boundary. This lets you make a quarter-model of a cylindrical tank without modeling the entire tank space, for instance. If you wrap the mesh 360 degrees around the axis, then you're modeling the whole tank, but you still use periodic boundaries to represent the connection between one end of the mesh and the other.
Old   September 11, 2013, 12:15
thank friend for your response
im studying a hydrocyclone in which we have rotary flow, this method works there? and another thing , u mean in cylindrical coordination the Ymax and Ymin represent the two starting and ending surfaces of cylindrical mesh?
Regards
Old   September 11, 2013, 15:08
Jeff Burnham
Yes, the Pd-boundaries in y work for rotating flow, and have been used for cyclonic modeling with FLOW-3D. - Jeff
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
setfileds for cylindrical mesh aki_yafuji OpenFOAM 3 December 9, 2010 21:35
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Define mesh motion in cylindrical CS rikio CFX 0 June 3, 2009 22:21
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
