Home > Forums > Software User Forums > FLOW-3D
Volumetric Flow Rate Graphically
Old   April 17, 2012, 08:14
Default Volumetric Flow Rate Graphically
Athmani Bassem
BAssem.at is on a distinguished road
Dear All,
I want to get a result as a graph, but I want to volumetric flow as a function of height of water ( Q=f(h) not Q=f(t) ).
Could you tell me how i can get it.
thanks,
Bassem
BAssem.at is offline   Reply With Quote
Old   April 17, 2012, 22:24
michael barkhudarov
MuxaB is on a distinguished road
Originally Posted by BAssem.at View Post
Dear All,
thanks,
Bassem
you can plot velocity as a function of a coordinate direction, but not Q, in FLOW-3D. If you use Tecplot, FieldView or Ensight, you can create new variables by integrating the flow rate over horizontal rows of cells and then plotting it as a function of height.
If not, then only modifying the FLOW-3D source code (e.g., BC.F) is the solution.
MuxaB is offline   Reply With Quote
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
how to set BC for compressible flow target mass flow rate foolboy007 FLUENT 1 April 4, 2012 03:24
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
Mass flow rate Neser CFX 4 February 14, 2004 00:27
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
