May 27, 2013, 04:46 |
Phase change due to radiation
mahmood
Hello every one. I m facing some problem. Hope you will advice me to solve it:
Problem: I want to simulate phase change due to solar radiation. Left is a photovolatic cell in which an inward heat flux is applied.Just after the Cell, there is air. After the air layer there is a alluminium cover. The PCM(Phase change materials) is after the cover. Now, the condition is 1) Heat flux is applied to the PV cell. So its temperature will rise(750 W/m2). 2) there will be an Energy loss due to convection and radiation to ambient (assume convective heat transfer cof: 10w/m2k). 3) The rest heat flux is imposed in the cover make it heated. As a result the PCM will melt. Question: I have defined the interfaces and coupled it for PV to Air, Air to cover, Cover to PCM. I can easily give heat flux in the left PV cell. But as the walls are coupled how can i define heat transfer co efficient for the air?? I used P1 radiation model along with solidification and melting. PLs any one can help me????? |
May 27, 2013, 22:05 |
mahmood
Can anyone help me??
May 31, 2013, 02:21 |
mahmood
no one for help????
heat flux, heat transfer coefficeint, radiation flux |
Effective heat capacity - Phase change does not work!!! | papteo | CFX | 8 | October 31, 2013 05:15 |
Refrigerant R134a Phase Change | Mahesh Bondhu | FLUENT | 4 | May 4, 2013 08:13 |
Phase change simulation in a tube. | AdarshGouda | FLUENT | 3 | April 25, 2013 00:55 |
Thermal Phase Change model | Niru | CFX | 0 | February 21, 2013 13:13 |
Phase change modelling | Sebastien DANIEL | FLUENT | 1 | July 6, 2000 03:35 |
