Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Need help for 3D-Nozzle cavitating flow!!!
Old   March 23, 2014, 21:51
Default Need help for 3D-Nozzle cavitating flow!!!
le hoang anh
lehoanganh07 is on a distinguished road
Dear Fluent-user,
I am using mixture model to modeling my object, which is 3D rectangular Nozzle.
The boundary conditions are:
-Inlet: pressure inlet (total pressure and static pressure)
-Outlet: static pressure
-Cavitation model: Schnerr and Sauer model
-Turbulent model: RNG k-epsilon with enhan wall function
Solution scheme: PISO unsteady
-pressure: second order
-vapor equation: QUICK
-Other equation: second order upwind
But the results seem different with experiment result and when I check average static pressure at Inlet, the value is equal the setting total pressure.
I dont know why had this results.
Is this solution method and orther option I chose correct and any suggestion for my problem?
Thank you very much!
lehoanganh07 is offline   Reply With Quote
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
calculate a nozzle flow using rhoCentralFoam hg2lf OpenFOAM 0 October 25, 2012 21:26
Cavitating Flow around a hydrofoil kimotbwb CFX 0 October 7, 2012 10:05
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
