Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
VOF: Sharp Interface
Old   May 12, 2014, 05:58
Default VOF: Sharp Interface
Jan Galijasevic
Jan90 is on a distinguished road
I am simulating in 2D an injection of water in a tank filled with oil through a circle on the left (velocity inlet). The right circle is producing just oil (negative velocity inlet).
My questions: Why am I missing a sharpt interface while using the VOF method? There should not be a green zone. (red is oil and blue is water)
Thanks
Jan90 is offline   Reply With Quote
Old   May 21, 2014, 19:29
Sean Delfel
delfel is on a distinguished road
Thanks
Hi there,
Do you have any more details on the schemes you are using? In general, my recommendations would be to a) use a better volume fraction scheme to reduce numerical diffusion (I tend to prefer compressive or BGM for sharp interfaces), b) adapt and improve the grid resolution at the interface, c) run the simulation transient as your jet may be causing entrainment between the two fluids.
Hope that helps.
delfel is offline   Reply With Quote
Old   May 29, 2014, 22:02
赵后剑
Bob-zhao is on a distinguished road
Thanks
Hi,here:
Could you tell me when you are setting the VOF model,you choose the explicit or the implicit? In my opinion, if you want to see the sharp interface,
choose the "explicit".
Bob-zhao is offline   Reply With Quote
Old   May 29, 2014, 22:13
Sean Delfel
Originally Posted by Bob-zhao View Post
Hi,here:
Yes, I agree with Bob. Explicit geo reconstruct will ensure that you capture a sharp interface. It requires a small time step, however, and you may be able to get adequate results with an implicit scheme.
Old   June 20, 2014, 08:36
Jan Galijasevic
Thank you very much for the reply.
I am using VOF, Implicit Scheme and PISO Scheme, Least Squares Cell Based Gradient, PRESTO! Pressure, Second Order Upwind Momentum, Compressive Volume Fraction and First Order Upwind Turbulent Kinetic Energy.
I will try it with an explicit scheme.
Regards,
Jan
Old   June 20, 2014, 22:48
Christopher Hershey
Hershey is on a distinguished road
If the viscosity of your two phases are also significantly different (an order of magnitude or more) then CICSAM is recommended with an explicit VOF model. Also, as delle pointed out, the sharpness of the interface is also a function of the mesh cell size. Make sure your mesh is refined in the area near the interface.
Hershey is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
