January 20, 2016, 14:40 |
Boundary Conditions in a gas stirred tank.
Hi everyone,
I am a beginner using Fluent. I am trying to simulate a gas stirred tank using Eulerian multiphase model. The case is about a tank full of water and the tank had a gas inlet in the center of the bottom of the tank. The Modelo is 2D. I am using the pressure-based solver. The tank is open to atmosphere, allowing the escape of injected gas. How can I set the atmospheric pressure (101325 Pa) in the top of the tank? What operating pressure condition should I establish? The gas inlet is a velocity-inlet type of boundary and the value is 0.61 m/s. However, the condition needs a initial pressure gauge, What is the value that I have to set? I hope you can help me and thank you for all your comments. |
January 22, 2016, 01:07 |
if it is open to the atmosphere just leave them as 0. both for the inlet and the outlet. (i think)
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Boundary conditions for gas dispersion case | DarrenC | FLUENT | 0 | April 10, 2014 05:26 |
ribbed channel / simpleFoam / boundary conditions | beeo | OpenFOAM Pre-Processing | 20 | July 17, 2013 08:39 |
