July 7, 2016, 13:12 |
DPM integration time step
Rep Power: 9 |
hello everybody ,
I am trying to simulate particle deposition in a 90 bend and I have problem with choosing a proper integration time step. according to fluent 6.3 help: "The integration time step is computed by Fluent based on a characteristic time that is related to an estimate of the time required for the particle to traverse the current continuous phase control volume. If this estimated transit time is defined as (delta t star) , then fluent chooses a time step (delta t ) as : (delta t star/landa)" the continuous phase has been solved steadily and the particles will be tracked unsteadily. what i want to know is that : fluent chooses a time step based on the equation above and on the other hand we determine a time step in the DPM window in the unsteady particle tracking section. i want to know what is the difference between the discretized time step that we determine and the time step that fluent chooses ? I appreciate your attention . |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
