Any Differences in Parallel UDF going from 2D to 3D?
Like Tree1Likes
  • 1 Post By blackmask
Old   July 8, 2013, 07:57
Default Any Differences in Parallel UDF going from 2D to 3D?
Christopher Hershey
Hershey is on a distinguished road
I have currently been working on my 2D simulations and my parallel UDF work quite well. Are there any compiler directives that need to be included when working in 3D?
I am only using two DEFINE_PROPERTY UDFs and one DEFINE_ADJUST UDF.
Thank you.
Hershey is offline   Reply With Quote
Old   July 8, 2013, 21:30
blackmask will become famous soon enough
There would be differences between 2D and 3D simulations, e.g., the area for 2d axisymmetric and 3d might differ. But as far as I am concerned, there is no parallel-specific difference.
blackmask is offline   Reply With Quote
Old   July 8, 2013, 21:35
Christopher Hershey
Thank you. Yes, my UDF are not specific to the actual dimension of the problem, just the boundary threads.
I seem to recall seeing a compiler directive #if RP_3D at some point and was not sure what it would be for. I guess your statement in dimensional dependent UDFs might explain its use.
Old   July 14, 2013, 11:39
kornetka's Avatar
kornetka is on a distinguished road
Hi
I have problem with different results for UDF computed in serial and parallel modes. I use parallel mode in order to utilize multicore processor on a single machine, if it makes any difference.
Attached mesh picture is 2D section of the middle plane of the canal - the case is 3D. Two other pictures presents distribution of the same UDM quantity in this middle plane. Both serial and parallel cases were computed with identical starting conditions, compiled UDF file is also exactly the same.
I have no idea why it is happening and how to deal with it. Can somebody explain it? Should I add some more information? Thanks in advance.
Regards,
kornetka
kornetka is offline   Reply With Quote
Old   July 14, 2013, 13:46
Christopher Hershey
Originally Posted by kornetka View Post
Hi
Regards,
kornetka
You may want to post your UDF to the thread. The problem may be that you are not properly passing information between the cores if you are saying that the UDF is identical in parallel as it is in serial.
I use a UDF that does the same calculation in parallel, but it is parallelized to do so. Have you done this with your UDF?
Old   July 14, 2013, 14:34
kornetka's Avatar
Thank you for your answer. As a matter of fact, up to now I had no idea about any parallelization so my UDF is probably not adjusted at all.
I think I'll read some manual and try to fix it myself for now. I'll come back here if (when ) I face some more troubles.
Regards,
kornetka
Old   July 19, 2013, 04:07
kornetka's Avatar
Hi, unfortunately I'm back.
I've read the part of the UDF manual about parallelization, but I wasn't able to locate solution to my problem. As you can see, my UDF loops over a cell fluid cell thread and inside every cell does a loop over all faces. In the face loop it is supposed to take values from the adjacent cells (dudux1, ...) and perform simple operation (SRT1, Sface - still inside the face loop). The result of the face loop is tensor DS, but it's broken - the distribution of DS[0][0] is attached to my previous post, other elements of the DS tensor have the same problem.
I suppose the fishy part is the taking values from the adjacent cells? As stated earlier, due to the type of the tasks done by this code I'm not able see the problem in the parallelization itself, though the problem clearly exists. What am I overlooking? Or could it be some problem with the hardwawre/firewall/etc?
Regards, kornetka
DEFINE_ADJUST(adj_turb_var, domain)
    int ii,jj,kk,n;
    real dudx,dudy,dudz,dvdx,dvdy,dvdz,dwdx,dwdy,dwdz;
    real dudx1,dudy1,dudz1,dvdx1,dvdy1,dvdz1,dwdx1,dwdy1,dwdz1;
    real SRT[3][3], SRT1[3][3], Sface[3][3];
    real DS[3][3];
    #if !RP_Host
    face_t f=-1;
    cell_t c,c1=-1;
    Thread *t,*t1=NULL,*tf=NULL;
/*    ID=2 is fluid zone    */
    t = Lookup_Thread(domain, 2);
    thread_loop_c (t, domain)
        begin_c_loop(c,t)
/*    Strain rate tensor in cell centre    */
            dudx = C_U_G(c,t)[0];
            dudy = C_U_G(c,t)[1];
            dudz = C_U_G(c,t)[2];
            dvdx = C_V_G(c,t)[0];
            dvdy = C_V_G(c,t)[1];
            dvdz = C_V_G(c,t)[2];
            dwdx = C_W_G(c,t)[0];
            dwdy = C_W_G(c,t)[1];
            dwdz = C_W_G(c,t)[2];
            SRT[0][0] = 0.5*(dudx + dudx);
            SRT[0][1] = 0.5*(dudy + dvdx);
            SRT[0][2] = 0.5*(dudz + dwdx);
            SRT[1][0] = 0.5*(dvdx + dudy);
            SRT[1][1] = 0.5*(dvdy + dvdy);
            SRT[1][2] = 0.5*(dvdz + dwdy);
            SRT[2][0] = 0.5*(dwdx + dudz);
            SRT[2][1] = 0.5*(dwdy + dvdz);
            SRT[2][2] = 0.5*(dwdz + dwdz);
            c_face_loop(c,t,n)
                f = C_FACE(c,t,n);
                tf = C_FACE_THREAD(c,t,n);
/*    Strain rate tensor in adjacent cell, if it exists    */
                if PRINCIPAL_FACE_P(f,tf)
                    if (!BOUNDARY_FACE_THREAD_P(tf))
/* Get cell on other side of face */
                        c1 = F_C1(f,tf);
                        t1 = F_C1_THREAD(f,tf);
                        dudx1 = C_U_G(c1,t1)[0];
                        dudy1 = C_U_G(c1,t1)[1];
                        dudz1 = C_U_G(c1,t1)[2];
                        dvdx1 = C_V_G(c1,t1)[0];
                        dvdy1 = C_V_G(c1,t1)[1];
                        dvdz1 = C_V_G(c1,t1)[2];
                        dwdx1 = C_W_G(c1,t1)[0];
                        dwdy1 = C_W_G(c1,t1)[1];
                        dwdz1 = C_W_G(c1,t1)[2];
                        SRT1[0][0] = 0.5*(dudx1 + dudx1);
                        SRT1[0][1] = 0.5*(dudy1 + dvdx1);
                        SRT1[0][2] = 0.5*(dudz1 + dwdx1);
                        SRT1[1][0] = 0.5*(dvdx1 + dudy1);
                        SRT1[1][1] = 0.5*(dvdy1 + dvdy1);
                        SRT1[1][2] = 0.5*(dvdz1 + dwdy1);
                        SRT1[2][0] = 0.5*(dwdx1 + dudz1);
                        SRT1[2][1] = 0.5*(dwdy1 + dvdz1);
                        SRT1[2][2] = 0.5*(dwdz1 + dwdz1);
/*    Strain rate tensor on the face    */
                        Sface[0][0] = 0.5*(SRT[0][0] + SRT1[0][0]);
                        Sface[0][1] = 0.5*(SRT[0][1] + SRT1[0][1]);
                        Sface[0][2] = 0.5*(SRT[0][2] + SRT1[0][2]);
                        Sface[1][0] = 0.5*(SRT[1][0] + SRT1[1][0]);
                        Sface[1][1] = 0.5*(SRT[1][1] + SRT1[1][1]);
                        Sface[1][2] = 0.5*(SRT[1][2] + SRT1[1][2]);
                        Sface[2][0] = 0.5*(SRT[2][0] + SRT1[2][0]);
                        Sface[2][1] = 0.5*(SRT[2][1] + SRT1[2][1]);
                        Sface[2][2] = 0.5*(SRT[2][2] + SRT1[2][2]);
                    else
                        Sface[0][0] = 0.0;
                        Sface[0][1] = 0.0;
                        Sface[0][2] = 0.0;
                        Sface[1][0] = 0.0;
                        Sface[1][1] = 0.0;
                        Sface[1][2] = 0.0;
                        Sface[2][0] = 0.0;
                        Sface[2][1] = 0.0;
                        Sface[2][2] = 0.0;
/*    Numerator for some other formula    */
                for(ii=0; ii<3; ii++)
                    for(jj=0; jj<3; jj++)
                        DS[ii][jj] += Sface[ii][jj];
            }    /*    Here ends the face loop    */
        end_c_loop(c,t)
    #endif
Old   July 19, 2013, 04:26
Please explicitly initialize the DS array, otherwise the results of DS is undefined after the function call.
kornetka likes this.
Old   July 19, 2013, 12:32
kornetka's Avatar
Thank you. I added the initialization at the beggining of the cell loop and it works now.
Regards, kornetka
"Define_Profile" UDF for parallel solver Antoine Fluent UDF and Scheme Programming 9 February 29, 2016 06:09
Differences of parallel UDF for Fluent 6.3 and 13 didiean Fluent UDF and Scheme Programming 9 March 25, 2013 21:37
UDF Error with Parallel affter several step trantoan2008 Fluent UDF and Scheme Programming 0 January 7, 2013 07:33
Parallel UDF Error Andrew FLUENT 2 March 30, 2007 11:11
UDF in parallel version of fluent yobee FLUENT 2 August 5, 2004 00:36
