How can i check that my UDF is being used in fluent istead of its internal data
Old   June 7, 2012, 20:47
Default How can i check that my UDF is being used in fluent istead of its internal data
chemkin is on a distinguished road
Dear all
I have written a UDF of volumetric reaction rate and hooked it in fluent. i want to know that is fluent using my UDF or the data i have given by user interface in material options.
and i also want to know that can i use " relax to chemical equilibrium" along with UDF in fluent.
Thanks in advance for your time and concern.
chemkin is offline   Reply With Quote
Old   June 8, 2012, 03:20
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I think you can add to your udf some i/o functions, such as printf and verify from the console (a sort of debug)..
But why fluent shouldn't use your options/udf?
Daniele
ghost82 is offline   Reply With Quote
Old   June 8, 2012, 05:19
thanks buddy for help
actually first i hook the UDF and after some iterations unhook it. there is no effect. but when i change the data , in place of which this udf is being used, in fluent user interface effect came into pic. thatswhy i was confused that does this usf is being used or not.
by the way the function that you are talking about, cna you describe it a bit deep???
Old   June 8, 2012, 07:53
ghost82's Avatar
Rick
Check this:
http://hpce.iitm.ac.in/website/Manua...df/node260.htm
You can place some printf inside your udf to see values which fluent is using during the simulation.
Old   June 8, 2012, 08:07
thanks man thanks a lot for the link. i used Message built in macro instead of printf . it is working .. thanks again
relax to chemical, udf, user interface, volm reaction rate
accessing solver data with UDF macros Dushan FLUENT 1 April 22, 2017 21:05
Please check out my parallelized udf code aleisia Fluent UDF and Scheme Programming 0 June 10, 2011 16:16
UDF in Fluent subha_meter Main CFD Forum 0 October 17, 2009 23:54
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
UDF (write a data file) problem lichun Dong FLUENT 2 July 29, 2005 11:39
