[HELP] Value range of a returned variable
Old   July 5, 2012, 10:42
Default [HELP] Value range of a returned variable
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Hi there, It's me again.
Since I am still simulating a laser fusion melting process, I ran into a completely new problem.
The heat sources I use for my calculations are computed using a UDF.
It looks like this:
DEFINE_SOURCE(sourceterm,c,t,dS,eqn)
...lots of code...
return source;
Now here is the thing: the returned variable ("source" in this case) has a limited range. Apparently it seems to be restricted to the range of a signed long integer -2,147,483,648 to 2,147,483,647).
All variables were initialized as "double" and I am running the case in double precision, so the problem is definitely the range of the returned variable.
Now the intensities of a laser beam are very high, so I need higher values of the returned variable.
What can I do?
flotus1 is offline   Reply With Quote
OpenFoam-1.6-ext Allwmake compilation error - one last barrier Pat84 OpenFOAM Installation 15 July 25, 2012 21:49
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
