UDF for heat convection coefficient with fixed surface temperature |
July 10, 2012, 08:57 |
Chun Wheng
Hello everyone.
I am basically doing a simulation for air flow in a room. What i would like to know if it would it be possible to specify a fixed heat transfer coefficient for the heat transfer into the fluid domain and a fixed surface temperature for a surface as boundary conditions? Would it be possible with a UDF? I was looking through the UDF manual and saw that Define_Profile allow for the specification of a heat transfer coefficient, however i think its for an external flow outside the domain. Am i right? CFX has this feature that allows for the specification of heat transfer coefficients via CCL by replacing the turbulent wall function. Therefore how would it be possible to create a UDF to allow the input of both Heat transfer coefficient and fixed surface temperature into the fluid domain. If so can anyone direct me to a right direction. Thanks alot! |
July 10, 2012, 10:38 |
Alex
Rep Power: 47 |
If the fluid is inside the domain you are simulating, the heat transfer coefficient cannot be a constant value.
It depends on the flow and turbulence conditions next to the wall, which are a result of the simulation. |
July 10, 2012, 18:43 |
Chun Wheng
I felt this was funny at first as the heat transfer into the fluid in cfd is due to the fluid flow thus usually a convective heat transfer coefficient is not defined. however I have seen papers that do this by disabling the wall functions and fixing a heat transfer coefficient instead.
cfx also allows for this, via a ccl by change the wall functions. that's y I am wondering if fluent can do the same. |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
Fixed mean temperature boundary condition for developing flow | mohsen cheraghi | OpenFOAM | 2 | July 24, 2011 13:06 |
Surface reaction rate temperature dependence | tumbao | FLUENT | 1 | February 17, 2011 09:14 |
