simulating Heat flux
Old   August 14, 2012, 04:27
Default simulating Heat flux
B Aram
landa is on a distinguished road
Hi
i want to define solar radiation as a heat flux BC for my problem. i have its average quantity per month (in w/m^2) for a year and i want to define it for fluent. i think i should use define_profile but i'm not good at prgramming especialy in c and also i'm newbie in defining udf.
can someone please kindly share a sample udf program for me?
thanks in advance
landa is offline   Reply With Quote
Old   August 14, 2012, 22:26
Syavash Asgari
syavash is on a distinguished road
Originally Posted by landa View Post
Hi
thanks in advance
Hi landa,
You may reffere to Fluent UDF manual. There are some good examples on Define_profile in there. You just need to copy one of thouse and pase it in a C file. Then you can change the F_profile value depending on your need. It's so simple, Just take a look and make it!
Good luck
syavash is offline   Reply With Quote
Old   August 15, 2012, 02:53
B Aram
i did so. can u please kindly take a look at it to see whether it has any problem.
this program includes heat flux for 3 days
#include"udf.h"
DEFINE_PROFILE(flux,th,i)
face_t f;
begin_f_loop(f,th)
if(CURRENT_TIME <= 86400.0 )
F_PROFILE(f,th,i) = 300.0;
elseif(CURRENT_TIME <= 172800.0 && CURRENT_TIME > 86400.0 )
F_PROFILE(f,th,i) = 310 ;
elseif(CURRENT_TIME <= 259200.0 && CURRENT_TIME > 172800.0 )
F_PROFILE(f,th,i) = 320 ;
else (CURRENT_TIME <= 345600.0 && CURRENT_TIME > 259200.0 )
F_PROFILE(f,th,i) = 330 ;
end_f_loop(f,th);
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 03:27
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 16:25
Negative Heat Flux shashank312 FLUENT 3 December 9, 2011 17:00
heat flux as a function of angle uncle_salty FLUENT 2 November 11, 2009 18:03
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 19:01
