DEFINE_INIT parallel udf error during solution initialization
Old   March 23, 2013, 09:48
Default DEFINE_INIT parallel udf error during solution initialization
nadesan
nadesan is on a distinguished road
hi,
I wrote a parallel udf to initialize the x, y and z velocity, for a 3D open channel flow case, using "DEFINE_INIT". Following is my code
#include "udf.h"
#include "metric.h"
#include "mem.h"
#define ymax 0.001
DEFINE_INIT(flow_field,d)
#if !RP_HOST
face_t f;
Thread *tf;
real x[ND_ND];
real y;
/**loop over all face threads in the domain**/
thread_loop_f(tf,d)
/**loop over all faces in the face thread**/
begin_f_loop(f,tf)
if PRINCIPAL_FACE_P(f,tf)
F_CENTROID(x,f,tf);
y=x[1];
F_U(f,tf)=(ymax+y)*(ymax-y)*48.6/(ymax*ymax);
F_V(f,tf)=0.0;
F_W(f,tf)=0.0;
end_f_loop(f,tf)
#endif
The code is in tact while compiling and loading. But while i am initializing the solution i am getting an error which reads
"stack backtrace generated for node id=0 (pid=17332) on signal 11"
999999: mpt_read:error:read failed trying to read 4 bytes: Resource temporarily unavailable.
The fluent process could not be started
Could someone please throw some light on this issue. Your help is much appreciated
Thanks a lot
Rgds
nadesan
nadesan is offline   Reply With Quote
"Define_Profile" UDF for parallel solver Antoine Fluent UDF and Scheme Programming 9 February 29, 2016 06:09
Parallel Fluent +UDF Jack Martinez FLUENT 0 June 28, 2007 11:19
Parallel UDF Error Andrew FLUENT 2 March 30, 2007 11:11
UDF for parallel computation Stanislav Kraev FLUENT 3 October 10, 2006 03:12
UDF in parallel analysis? Ricky FLUENT 0 May 5, 2003 04:44
