velocity profile for inlet with UDF
Old   September 12, 2012, 03:51
Default velocity profile for inlet with UDF
selim
salihovic is on a distinguished road
Dear all,
I want to impose a velocity at the inlet which is parabolic at the bottom and top and constant in the middle of the inlet. But flunet does not regonize the locations correctly, so what is wrong in my UDF, pls help!!
Here is my udf,
#include "udf.h"
#define S 0.038
#define V1 10.86
DEFINE_PROFILE(inlet_x_velocity, thread, index)
real x[ND_ND]; /* this will hold the position vector */
real y;
face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
y = x[1];
if (y<=S)
F_PROFILE(f, thread, index) = 249.384*y*y+249.384*y;
else if (S<=y<=3*S)
F_PROFILE(f, thread, index) = V1;
else if (3*S<=y<=4*S)
F_PROFILE(f, thread, index) = -83.514*y*y-83.514*y+14.6238;
end_f_loop(f, thread)
Thank you,
-Selim
salihovic is offline   Reply With Quote
Old   September 12, 2012, 04:51
Zhi-Gang Zhai
zgzhai is on a distinguished road
pls show the mesh and what is the wrong result ? thank you!
zgzhai is offline   Reply With Quote
Old   September 12, 2012, 05:45
ghost82's Avatar
Rick
ghost82 will become famous soon enough
the following udf will produce the following velocity-y coordinate chart; velocity will be a function of the only y coordinate.
Take care to operators <=, >= etc.: in your udf, if for example y=S both
are valid
#include "udf.h"
#define S 0.038
#define V1 10.86
    real y;
    face_t f;
        y = x[1];
        if (y<=S)        /* y=S is included */
        else if (S<y<3*S)        /* y=S and y=3S are not included */
        else /* no need for another else if, 3S is included here */
ghost82 is offline   Reply With Quote
UDF problems - velocity profile Oli Fluent UDF and Scheme Programming 6 October 24, 2016 10:38
UDF Unsteady velocity profile Rashad FLUENT 0 February 27, 2008 14:57
How to specify the Velocity profile (eqn) by UDF Anant FLUENT 1 February 27, 2008 14:54
Multi step transient UDF velocity profile problem William177 FLUENT 1 February 3, 2008 06:47
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
