September 23, 2012, 09:29 |
UDF error...after compilation
Mukesh
Hello All,
here is my UDF for source term of scalar eqn. #include"udf.h" #define DELTA_S 107.2 #define DELTA_H 28000 #define k_a 75 #define R_u 8.314 #define phi_s 0.35 #define phi_o 0.15 #define phi 0.2 #define PI 3.14159265359 DEFINE_SOURCE(uds_source,c,t,ds,eqn) { real tp; real rate; real P_eq; real arg; real hys; arg = PI*(C_UDSI_M1(c,t,0) - 0.5); hys = tan (arg); tp = C_T(c,t); C_UDMI(c,t,2)=tp; P_eq = pow(2.72,((DELTA_S/R_u)-(DELTA_H/(R_u*tp))+((phi_s+phi_o)*hys)+(phi/2)))*pow(10,5); C_UDMI(c,t,3)= P_eq; rate = k_a*pow(2.72,(-E_a/(R_u*tp)))*((P_i-P_eq)/P_eq)*(1-C_UDSI_M1(c,t,0)); C_UDMI(c,t,4)=rate; return rate; } This code is compiling and not showing any error BUT as soon as I run it for iterations: the very first message is "error: floating point error : Invalid no" Observation: when I didn't incorporated the ' tan(arg) ' part (along with phi_s, phi_o, phi, arg) it will iterate well. Could anyone please figure what could be the reason as without incorporating these I won't get the correct result. here is my actual eqn for P_eq as attachment for your refernce. Thanking in advance. ---------------- Regards, Mukesh Last edited by er.mkumar; November 12, 2012 at 03:52. |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 05:11 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
