Defining a source term
Prev Previous Post   Next Post Next
Old   September 28, 2012, 08:00
Default Defining a source term
fleure_Jasmin is on a distinguished road
I’m trying to create an UDF which define an ultrasonic source term in the momentum equation, and I have the analytical expression of the radiation pressure/ volume :S = a exp(- r2) exp (-x2) ; where “a” is a constant, “ r” is the radial component ant” x” is the axial one.
The function must return an x-momentum source term that varies with x and r position
The problem here is that the expression is not depending on x-velocity Vx so we can set dS[eqn] to dS/dVx
Do you have please any idea about haw can I write this UDF in a different way from that of the UDF manual-section 4.3.15
Thank you, I will be grateful
fleure_Jasmin is offline   Reply With Quote
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
gradient source term UDF ak6g08 Fluent UDF and Scheme Programming 0 July 9, 2009 06:37
Source term defining in k-epsilon equation Q FLUENT 0 March 8, 2006 11:52
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
