Looping in UDF
Old   October 22, 2012, 05:46
Question Looping in UDF
sg24589 is on a distinguished road
I am a starter in UDF. In a particular problem, I want to give an inlet velocity in a pipe using UDF. I am confused as to whether I should use looping over cells or looping over faces. What difference would it produce in results and why.....?
Plz help.....Thanks in advance....
sg24589 is offline   Reply With Quote
Old   October 22, 2012, 12:20
Syavash Asgari
syavash is on a distinguished road
You should loop over faces at inlet. Velocity is a Boundary condition. You must apply it to inlet faces not cells.
syavash is offline   Reply With Quote
Old   November 30, 2012, 01:58
Thanks a lot for the reply.....
That's what is confusing me actually. It's a boundary condition, and I need to give it to the whole face. Is it that if I loop over faces, after the first iteration the values at each cell of a face will be calculated separately and stored which will be used for every subsequent calculation.
One more question - In sixdof udf solver in fluent, we have to mention moment of inertia, product of inertia among others. Is this mass moment of inertia or area moment of inertia. Also it is to be input about which point (center of gravity or geometric center).
Thank You....
Old   December 1, 2012, 00:03
Syavash Asgari
Thank You....
1-
When you apply B.C. to certain faces of a boundary, Fluent needs to initialize the flow field by a initial condition, often the same value(s) of inlet B.C. considered. The values which you specified as B.C. is constant during the whole simulation for faces (unless you consider changing it with time in a transient case!). The first layer of cells adjacent to boundary faces are treated same as the interior cells and you don't need to specify anything to them.
2-
It refers to mass moment of inertia. The second part should be already clear! It's center of gravity.
Good luck.
Old   December 3, 2012, 00:45
Thanks a lot
I understood the answer too.
Looping inside UDF and use of C_UDMs in DEFINE_DPM_BC shankara.2 Fluent UDF and Scheme Programming 0 November 10, 2009 17:11
looping UDF in given direction ak6g08 Fluent UDF and Scheme Programming 0 September 10, 2009 10:13
Looping in UDF!!! safa FLUENT 0 December 11, 2007 08:07
Looping over nodes of a cell (UDF) error Manoj FLUENT 2 December 1, 2005 00:30
UDF for looping over nodes in cells. Malcolm Wallace FLUENT 3 July 3, 2000 09:22
