UDF saturation temperature (evaporation model Fluent) |
June 18, 2019, 04:24 |
Rep Power: 6 |
Hi everyone,
I want to simulate the evaporation of water with VOF model (water-liquid to water-vapor). I am using the evaporation-condensation model. In this model, we can put the desired saturation temperature (373.15 K for water). However this value is not always constant because it can change with pressure. I want to evaporate water by decreasing the pressure. That's why I want to create a UDF to compute this saturation temperature in function of pressure (if pressure decreases, the saturation temperature decreases too...). Here what I wrote (but nothing happens) : #include "udf.h" DEFINE_PROPERTY(saturation_temp,c,t) { real sat_t; real vapor_p; real static_p = C_P(c,t); real operating_p = RP_Get_Float("operating-pressure"); vapor_p = static_p + operating_p; // absolute pressure = static pressure + operating pressure sat_t = (1723.6425/(8.05573-log(vapor_p/133.322))-233.08)+273.15; // Pressure in Pa to mmHg (Yaws) return sat_t; } I cannot find something about it, I do not know if I have to use DEFINE_PROPERTY... Can anyone help me? Thanks in advance! |
June 19, 2019, 00:03 |
Alexander
Rep Power: 34 |
you should hook your UDF
change constant 373.15K to your UDF function best regards |
June 19, 2019, 03:28 |
#3 | |
Rep Power: 6 |
So the problem is still here. Do you think a DEFINE_PROPERTY is ok to define the temperature? Last edited by bbarbier07; June 19, 2019 at 04:28. |
June 20, 2019, 00:45 |
Alexander
Rep Power: 34 |
yes it is OK
try this Code:
#include "udf.h" DEFINE_PROPERTY(saturation_temp,c,t) { real sat_t; real vapor_p; real static_p; real operating_p; static_p=C_P(c,t); operating_p = RP_Get_Float("operating-pressure"); vapor_p = static_p + operating_p; // absolute pressure = static pressure + operating pressure sat_t = (1723.6425/(8.05573-log(vapor_p/133.322))-233.08)+273.15; // Pressure in Pa to mmHg (Yaws) return sat_t; } |
June 20, 2019, 03:30 |
#5 | |
Rep Power: 6 |
Actually I want to evaporate water liquid (to water vapor) in a 2D container by warming the bottom wall. I did it correctly with the saturation temperature as a constant but when I replace with my UDF nothing happens, there is no water vapor. I should get the same result as the case with a constant... If you have another idea thanks in advance... Best regards |
June 20, 2019, 21:19 |
Alexander
Rep Power: 34 |
#include "udf.h" DEFINE_PROPERTY(saturation_temp,c,t) { return 373.15; } best regards |
June 21, 2019, 03:44 |
Rep Power: 6 |
I tried it, it works well so UDF works but not the one function of pressure...
Best regards |
June 21, 2019, 05:03 |
Alexander
Rep Power: 34 |
1. try with othe temperature 300, 400
2. try this Code:
#include "udf.h" DEFINE_PROPERTY(saturation_temp,c,t) { real sat_t; real vapor_p; vapor_p = C_P(c,t) + op_pres; // absolute pressure = static pressure + operating pressure sat_t = (1723.6425/(8.05573-log(vapor_p/133.322))-233.08)+273.15; // Pressure in Pa to mmHg (Yaws) return sat_t; } |
June 21, 2019, 05:54 |
#9 |
Rep Power: 6 |
I have found the solution!
Actually, there were 2 problems in my UDF. The first one was the operating pressure: change Float to Real. The second was with the "log": the correct formulation for a variable is "double log10 (double x)". You can find the final code: #include "udf.h" DEFINE_PROPERTY(saturation_temp,c,t) { real sat_t; real vapor_p; real static_p = C_P(c,t); real operating_p = RP_Get_Real ("operating-pressure"); vapor_p = static_p + operating_p; // absolute pressure = static pressure + operating pressure sat_t = (1723.6425/(8.05573-((double)log10((double)vapor_p/133.322)))-233.08)+273.15; // Pressure in Pa to mmHg (Yaws) return sat_t; } |
June 23, 2019, 22:02 |
#10 |
Alexander
Rep Power: 34 |
when you start fluent in double precision regime all "reals" are double
best regards |
June 12, 2021, 23:35 |
#11 |
Stanlee
Rep Power: 8 |
Hi Sir,
Could you please help? I used your code and it goes "The computed saturation temperature <=0.0. What should I do? it has already driven me crazy!! |
June 15, 2021, 04:18 |
#12 |
Alexander
Rep Power: 34 |
most likely you didn't put correct operating pressure
best regards ****************************** press LIKE if this message was helpful |
March 14, 2024, 07:29 |
#13 | |
Bidax
Rep Power: 2 |
Hiiiii what is the basis of this formula "sat_t" is there a detailed explanation thanks in advance |
UDF to get the average temperature of a face and use it to define a property | gdb | Fluent UDF and Scheme Programming | 19 | November 3, 2022 03:11 |
UDF for temperature initialization in FLUENT | Ami24 | FLUENT | 0 | February 25, 2016 08:27 |
Evaporation heat loss modelling (water temperature below saturation)? | ahmedmmx | Fluent Multiphase | 1 | June 19, 2015 06:35 |
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 02:02 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 06:08 |
