calculate dimensionless temperature using udf
Old   November 10, 2015, 23:12
Default calculate dimensionless temperature using udf
Dantong Shi
lion1990 is on a distinguished road
I wrote a udf to calculate dimensionless temperature for post processing for a 3D problem. The followings are my udf code. It can be interpreted and executed on demand. However, when I look into the contour, it seems not right. After some trials, I guess it should be the ''if'' language went wrong. The results seems like the if () language doesn't work. Can someone tell me what's wrong with my udf? Especially the parts with ''if ()''.
#include "udf.h"
DEFINE_ON_DEMAND(dimensionless_temperature1)
Domain *d;
real dimensionless_t;
real twall = 400;
real temp;
real xmin = 0;
real xmax = 0.2667;
real deltax = 0.01;
real tbulk[27];
real integral_tuv[27];
real integral_uv[27];
Thread *t;
cell_t c;
real x[ND_ND];
int i;
d = Get_Domain(1); /* Get the domain using ANSYS Fluent utility */
thread_loop_c(t,d)
begin_c_loop(c,t)
C_CENTROID(x,c,t);
end_c_loop(c,t)
for(i=0; i<=0; i++)
integral_tuv[i]=0;
integral_uv[i]=0;
begin_c_loop(c,t)
if ((x[0]>=xmin+i*deltax) && (x[0]<=xmin+(i+1)*deltax))
integral_tuv[i] += C_T(c,t)*C_U(c,t)*C_VOLUME(c,t); integral_uv[i] += C_U(c,t)*C_VOLUME(c,t);
end_c_loop(c,t)
tbulk[i] = integral_tuv[i]/integral_uv[i];
begin_c_loop(c,t)
temp = C_T(c,t);
dimensionless_t = (temp-twall)/(tbulk[i]-twall);
C_UDMI(c,t,0) = dimensionless_t;
end_c_loop(c,t)
Thanks!
lion1990 is offline   Reply With Quote
dimensionless temperature, fluent, udf
UDF for Back-flow Temperature G340 Fluent UDF and Scheme Programming 3 August 21, 2013 04:56
Please Help! Temperature profile UDF for 3D geometry subhankar_bhandari FLUENT 2 April 16, 2011 05:30
Please Help! Temperature profile UDF for 3D geometry subhankar_bhandari FLUENT 0 August 16, 2010 08:40
Help please! UDF for Temperature profile in 3D subhankar_bhandari Fluent UDF and Scheme Programming 2 August 16, 2010 08:37
UDF: Repatching part temperature Mcgregor FLUENT 1 June 2, 2003 08:51
