UDF Error with Parallel affter several step
Old   January 7, 2013, 07:33
Default UDF Error with Parallel affter several step
ThanhToan
trantoan2008 is on a distinguished road
Send a message via Yahoo to trantoan2008 Send a message via Skype™ to trantoan2008
Hi all,
I faced strange problem while using UDF code with parallel processing. I run very my porblem with 32 time step. But, my solution broke down with below error message. Please tell me what's happended with my UDF code in parallel.
Thank you so much.
0 (..\src\mpsystem.c@1173): mpt_read: failed: errno = 10054
MPI Application rank 0 exited before MPI_Finalize() with status -1
0: mpt_read: error: read failed trying to read 8 bytes: No such file or directory
The Parallel FLUENT process could not be started.
trantoan2008 is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
UDF for linear temperature profile on horizontal parallel surfaces. Chirag2302 Fluent UDF and Scheme Programming 0 February 4, 2012 00:44
Transient pressure UDF for parallel fluent droberts Fluent UDF and Scheme Programming 5 October 11, 2010 04:13
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
