udf for wall slip
Like Tree3Likes
Old   January 9, 2013, 05:39
Cool udf for wall slip
ammm
ammm is on a distinguished road
i need a udf for slip wall
i want to use udf for setting this boundary condition:
us=B*(du/dy)
what should i do?
ammm is offline   Reply With Quote
Old   January 10, 2013, 01:49
SSL
msaeedsadeghi is on a distinguished road
I have already written it. Email me please.
tirmizi likes this.
msaeedsadeghi is offline   Reply With Quote
Old   January 10, 2013, 05:02
ammm
i emailed you thank you in advance
Old   January 12, 2013, 12:58
Farzad Ahamdi
fahmadi is on a distinguished road
Dear Mr Sadeghi
I also have written a UDF for slip velocity which works correctly, but when I want to add the term due to thermal creep, I get the below error:
"FLUENT received fatal signal (ACCESS_VIOLATION)."
I recognized that this error is due to using the expression "C_T_G(cell,t)" in my UDF.
Could you help me to solve this problem?
Thank you so much!
fahmadi is offline   Reply With Quote
Old   January 12, 2013, 23:26
SSL
Originally Posted by fahmadi View Post
Dear Mr Sadeghi
Thank you so much!
In most Micro-Channel problems there is no need to add the thermal creep section. You can neglect it.
Old   January 15, 2013, 09:19
ammm
i write this udf for slip. is it correct???
#include "udf.h"
DEFINE_PROFILE(shear_stressx, thread, n)
face_t f ;
cell_t c0 ;
Thread *t0 =THREAD_T0(thread) ;
float u0,uw,vderivate, sstressx ;
begin_f_loop(f, thread)
c0 = F_C0(f ,thread) ;
vderivate= C_DUDY(c0,t0) ;
u0 = C_U(c0, t0);
uw=u0+1*pow(10,-6)*vderivate ;
F_U(f, thread)=uw;
sstressx = -.001003*vderivate ;
F_PROFILE(f,thread,n) = sstressx ;
end_f_loop(f,thread)
Old   January 16, 2013, 04:49
Post How to write a slip condition in wall
asm
Jetica
asm is on a distinguished road
dear Mr Sadeghi and ammm:
i need a udf(fluent or cfx is ok) for slip wall.As ammm metioned,the slip wall
which can be attached with thermal creep is the best.But if the thermal creep is
excluded,that is ok. could you send me a udf you have writtern.please send
the email:asm23374634@gmail.com
thank you very much
asm is offline   Reply With Quote
Old   January 17, 2013, 05:03
ammm
my udf works good with low slip length but for larger slip length not converged. Can anyone guide me for this convergence problem?
i use fluent 6.2 and when i dont use udf it works corrctly
please help me
Old   February 22, 2013, 16:10
Shayan is on a distinguished road
Dear Mr Sadeghi
Thank you so much!
I had same problem, to avoid this problem,you should not hook all your UDFs at the same time; Step by step! first apply the udf of slip velocity, then let the iterations go, after your solution is converged`,unhook it and apply Thermal creep udf, let it go for numerous iterations, then re-apply slip-velocity udf again,
All of these operations is due to suitable initializations which help Fluent to start a solution from a rather logic guess.
each UDF produces a sudden jump in the resodual graph, so it's better avoiding 3 jumps at the same time, instead, imply them gradually.
Shayan is offline   Reply With Quote
Old   February 25, 2013, 04:32
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
please help me
Apply some under-relaxation.
Additionally, I can only emphasize once more that fluent comes with a BC of the type us=B*(du/dy).
It is called "Slip Boundary Formulation for Low-Pressure Gas System" and even includes the term for thermal creep.
Sadra.Forouzi likes this.
flotus1 is offline   Reply With Quote
Old   February 25, 2013, 23:44
SSL
I have done that before without thermal creep, but today have found how to consider thermal creep also.
It needs step by step enabling and disabling equations.
Old   March 4, 2013, 05:34
Katerina
Katerina is on a distinguished road
Dear all,
I'm doing a simulation with slip and VOF. I would like to define slip - shear stress for liquid only. But I'm doing it wrong.
My shear stress=mu*dudx*vof
What should I change to get C_VOF for correct thread ?
#include "udf.h"
DEFINE_PROFILE(wall_shear_y,thread,position)
face_t f;
Thread *t0, *t2, *t3;
cell_t c0;
double TAUxy, mu;
double dudx;
double vof;
begin_f_loop(f,thread)
t0=THREAD_T0(thread); /*adjacent cell index*/
c0=F_C0(f,thread); /*adjacent cell thread*/
t2 = THREAD_SUB_THREAD(t0, 0); // take ID of phase no.1
t3 = THREAD_SUB_THREAD(t0, 1); // take ID of phase no.2
dudx=C_DUDX(c0,t0);
mu=C_MU_L(c0,t0); /*viscosity*/
begin_c_loop(c0,t3)
vof=C_VOF(c0,t3); /*volume of fluid value in adjacent cell for phase 2*/
end_c_loop(c0,t3)
TAUxy=mu*dudx*vof;
F_PROFILE(f,thread,position)=TAUxy;
Regards,
Katerina
Katerina is offline   Reply With Quote
Old   March 26, 2014, 04:41
Default slip wall shear
  #13
elaf
elaf_2003 is on a distinguished road
I was wondering if any one can help me?
I am using flow around rotating cylinder, the shear stresses at the wall need to be specified to constant value. In this option, there are 3 components for the shear stresses, i.e. x direction components and so on.
Does anyone know for example how can set these values for cylinder surface
Regard.
elaf_2003 is offline   Reply With Quote
Old   November 13, 2014, 04:25
Default hi
  #14
Qureshi M Z I
m zahid is on a distinguished road
hi, i need a UDF for slip boundary condition at the bottom of the domain or at the ground (wall), 3D case is just like a flow over a building. if anybody have sample UDF please share this, z is a vertical axis of my domain. thanks
mziqureshi@hotmail.com
regards,
m zahid is offline   Reply With Quote
Old   May 15, 2017, 03:19
Default UDF Slip Rotational Wall
  #15
Widhi
Widhi is on a distinguished road
i need the udf for slip rotational wall. in this case i want to simulate for 2-d journal bearing. what should i do?
Thanks.
Widhi is offline   Reply With Quote
Old   June 22, 2017, 04:30
tae won
zmdxodnsj is on a distinguished road
Dear msaeedsadeghi
Hi I'm doing about micro-channel problem. so I need the udf(fluent) for slip condition for slip wall.
if you have udf of slip condition and temperature jump condition.
Could you send me the udf code? It doesn't matter if it not include thermal creep
my email : ssdssdblack@naver.com
thank you
zmdxodnsj is offline   Reply With Quote
Old   March 26, 2018, 06:49
Syed umer tirmizi
tirmizi is on a distinguished road
Can you send me the udf file for us=b*(du/dy) model .
Email :syedumer46@gmail.com
tirmizi is offline   Reply With Quote
Old   March 28, 2018, 04:58
golf du
buaadino is on a distinguished road
Would you please mail me the udf, thanks a lot! My e_mail is 4963404@qq.com
buaadino is offline   Reply With Quote
Old   March 28, 2018, 05:10
pakk will become famous soon enough
I hope anybody reading this is aware that low pressure boundary slip is for a long time already included in Fluent, without needing to add any UDFs. Look for "low pressure boundary slip" in the manual to find out more.
tirmizi likes this.
pakk is offline   Reply With Quote
Old   February 13, 2019, 10:03
Pratik Manna
Pratik_me is on a distinguished road
Dear Mr. Sadeghi
Can you mail me the UDF? I, require this UDF for a simulation of flow through a micro-channel. My e-mail is - bishaktomanush@gmail.com
regards
S. G. Das
Pratik_me is offline   Reply With Quote
UDF for slip boundary condition rasoulb Fluent UDF and Scheme Programming 15 October 15, 2021 03:35
UDF for slip and moving wall lichun Dong FLUENT 3 March 26, 2014 04:37
UDF slip and temperature jump from IFRT abir Fluent UDF and Scheme Programming 1 July 30, 2012 05:44
where to setting the slip wall in udf cxzhao FLUENT 4 July 4, 2005 02:56
why boudary slip velocity is so larte using udf cxzhao FLUENT 0 July 4, 2005 00:06
