fluent udf error while compiling: unknown type name __locale_t |
January 10, 2013, 02:02 |
Aditya Pandare
Rep Power: 13 |
I am trying to compile a simple "density variation with pressure" udf in Fluent 13 @ ubuntu 32bit
I get the following errors in the log file: (I have boldfaced the lines with error) # building library in lnx86/2ddp make[1]: Entering directory `/home/ifmg/AdityaKP/orifice/95k-axisym/cavitation-trial/libudf/lnx86/2ddp' # Generating udf_names.c because of makefile density_cell.c make[2]: Entering directory `/home/ifmg/AdityaKP/orifice/95k-axisym/cavitation-trial/libudf/lnx86/2ddp' make libudf.so "CFLAGS=-fpic -shared -ansi -Wall -m32 -O " "LDFLAGS=-shared -lm -m elf_i386" make[3]: Entering directory `/home/ifmg/AdityaKP/orifice/95k-axisym/cavitation-trial/libudf/lnx86/2ddp' # Compiling udf_names.o because of udf_names.c cc -fpic -shared -ansi -Wall -m32 -O -I/ansys_inc/v130/fluent/fluent13.0.0/`expr "\`pwd\`" : '.*/\(.*\)/[23].*'`/`basename "\`pwd\`"` -I/ansys_inc/v130/fluent/fluent13.0.0/src -I/ansys_inc/v130/fluent/fluent13.0.0/cortex/src -I/ansys_inc/v130/fluent/fluent13.0.0/client/src -I/ansys_inc/v130/fluent/fluent13.0.0/tgrid/src -I/ansys_inc/v130/fluent/fluent13.0.0/multiport/src -I/ansys_inc/v130/fluent/fluent13.0.0/multiport/mpi_wrapper/include -I/ansys_inc/v130/fluent/fluent13.0.0/multiport/mpi_wrapper/src -I. -c udf_names.c In file included from /usr/include/pthread.h:26:0, from /ansys_inc/v130/fluent/fluent13.0.0/multiport/src/mpthreads.h:13, from /ansys_inc/v130/fluent/fluent13.0.0/src/global.h:240, from /ansys_inc/v130/fluent/fluent13.0.0/src/udf.h:20, from udf_names.c:3: /usr/include/time.h:226:5: error: unknown type name ‘__locale_t’ make[3]: *** [udf_names.o] Error 1 # Compiling density_cell.o because of density_cell.c cc -fpic -shared -ansi -Wall -m32 -O -I/ansys_inc/v130/fluent/fluent13.0.0/`expr "\`pwd\`" : '.*/\(.*\)/[23].*'`/`basename "\`pwd\`"` -I/ansys_inc/v130/fluent/fluent13.0.0/src -I/ansys_inc/v130/fluent/fluent13.0.0/cortex/src -I/ansys_inc/v130/fluent/fluent13.0.0/client/src -I/ansys_inc/v130/fluent/fluent13.0.0/tgrid/src -I/ansys_inc/v130/fluent/fluent13.0.0/multiport/src -I/ansys_inc/v130/fluent/fluent13.0.0/multiport/mpi_wrapper/include -I/ansys_inc/v130/fluent/fluent13.0.0/multiport/mpi_wrapper/src -I. -c density_cell.c In file included from /usr/include/pthread.h:26:0, from /ansys_inc/v130/fluent/fluent13.0.0/multiport/src/mpthreads.h:13, from /ansys_inc/v130/fluent/fluent13.0.0/src/global.h:240, from /ansys_inc/v130/fluent/fluent13.0.0/src/udf.h:20, from density_cell.c:1: /usr/include/time.h:226:5: error: unknown type name ‘__locale_t’ make[3]: *** [density_cell.o] Error 1 make[3]: Target `libudf.so' not remade because of errors. make[3]: Leaving directory `/home/ifmg/AdityaKP/orifice/95k-axisym/cavitation-trial/libudf/lnx86/2ddp' make[2]: *** [lnx86] Error 2 make[2]: Leaving directory `/home/ifmg/AdityaKP/orifice/95k-axisym/cavitation-trial/libudf/lnx86/2ddp' make[1]: *** [default] Error 2 make[1]: Leaving directory `/home/ifmg/AdityaKP/orifice/95k-axisym/cavitation-trial/libudf/lnx86/2ddp' could I get some help with this? |
April 7, 2014, 01:28 |
fluent UDF error
Allamaprabhu C Y
Hi Aditya,
I am facing the same problem which you posted in 2013. Please let me know how you could solve it. I am getting the following error: /usr/include/time.h:226:5: error: unknown type name ‘__locale_t’ Eagerly awaiting your reply. regards, Allamaprabhu |
April 12, 2014, 09:46 |
Aditya Pandare
Rep Power: 13 |
I do not exactly remember how I had solved this issue. But I do remember that this PDF helped me a lot. I have attached it to this post. See if it helps you. |
April 12, 2014, 14:52 |
#4 | |
However, for 32 bit Linux OS you need to install C++ compiler, I am not sure that gcc/g++ will work in this case, but I am sure that you need to have C++ compiler which links correctly with your fluent for using its external compiler. Besides, please note to your UDF capability in case you are running in parallel. |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
second order schemes | marine | OpenFOAM | 67 | April 11, 2022 18:19 |
Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 18:34 |
LES supersonic free jet | martyn88 | OpenFOAM | 22 | April 17, 2015 06:00 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
