Problem with using UDF to modify viscosity
Like Tree2Likes
  • 1 Post By teethfish
  • 1 Post By akm
Old   February 3, 2013, 10:15
Default Problem with using UDF to modify viscosity
teethfish
teethfish is on a distinguished road
Hi, I want to modify the viscosity in K-W SST model in Fluent 13.0. But I met a problem that my UDF cannot initiate and it shows that:
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
I have tried initialise without using "compute from" ....but the error was still there, I pasted my UDF here, if anone can help me with that?
#include "udf.h"
DEFINE_TURBULENT_VISCOSITY(user_mu_t,c,t)
real mu_t;
real a;
real rho;
real k;
real d;
a=(C_R(c,t)-0.5542)/997.6458;
rho = 0.5542+a*a*997.6458;
k = C_K(c,t);
d = C_D(c,t);
mu_t = M_keCmu*rho*k*k/d;
return mu_t;
dongchao yang likes this.
teethfish is offline   Reply With Quote
Old   February 4, 2013, 08:03
Default Specific dissipation rate C_O(c,t)
akm
akm is on a distinguished road
If you are working with k-w turbulence model, the dissipation rate C_D(c,t) will not be available in the UDFs as it is not calculated by the solver. Instead, specific dissipation rate is calculated C_O(c,t).
For the purpose of your udf calculation, you can covert \omega to \epsilon as under:
http://www.cfd-online.com/Wiki/Speci...ssipation_rate
soheil_r7 likes this.
akm is offline   Reply With Quote
Old   February 4, 2013, 09:47
teethfish
Wow, thank you for your help, you really helped me a lot!
And I have one more question, when i use this UDF:
real mu_t;
real a;
real rho;
real k;
real d;
k = C_K(c,t);
d = C_D(c,t);
return mu_t;
with realizable k-epsilon model, the results diverged, but it worked well with the RNG-kepsilon model, are they actually different?
Old   May 1, 2013, 09:20
Sheng
micro11sl is on a distinguished road
Hi teethfish,
Did you get your problem sorted?
I have some problems using the modified turbulent viscosity problem as well. I guess, although you hook a same udf to different turbulence models, there're something different more than the udf. The boundary condition, wall treatment, may be different. So a possible circumstance is the solution behavior is different between two distinct turbulence model with an identical udf.
I am still investigating this.
Sheng
micro11sl is offline   Reply With Quote
Old   May 17, 2013, 07:33
Unhappy Error occurs in UDF for DPM viscosity
Barbara
Babs is on a distinguished road
Hello to you all,
I hope I post this in the right place, I did not found a more appropriate one...for an atomizer jet I have to write an UDF to express non- newtonian behaviour for the liquid phase. It is not possible to choose any non- newtonian models like cross or carreau or power- law for the DPM- material so I have to write this UDF. I want to realize the model of CROSS with this UDF.
I compiled this UDF and everything works fine but after exactly 9 iteration steps the same error as descriped above ocurrs:
Error:
Ansys received fatal signal (ACCESS VIOLATION)
4. Report error to your contributor.
Error: Object f#
The code I use for realizing the UDF (and that causes this error) is:
#include "udf.h"
#include "dpm.h"
DEFINE_DPM_PROPERTY(cell_viscosity_CROSS_m2, c, t, p)
real mu_INF,mu_0,k,mu_CROSS,m;
double aux,SR;
SR=C_STRAIN_RATE_MAG(c,t);
k=0.01372;
m=0.7857;
mu_0=1.885;
mu_INF=0.05320;
mu_CROSS=DPM_MU(p);
aux=pow(SR,m);
mu_CROSS=mu_INF+(mu_0-mu_INF)/(1+k*aux);
return mu_CROSS;
I treid it out in steady, in transient, I changed the URF, I just interpreted it I compiled it, but nothing helps...I guess there is some error in the code that I do not see....actually my programming skills are quite bad and I do not have any experience at all with UDF.
I would really appreciate if someone could help me or has some advice for me. Greetings and thank you, have a nice weekend!
Babs is offline   Reply With Quote
Old   May 17, 2013, 08:07
blackmask will become famous soon enough
Check one of the pointers before actually access them. Try add the highlighted line to see whether it helps.
double aux,SR;
if ( NULLP(T_STORAGE_R_NV(t, SV_U_G)) ) return;
k=0.01372;
m=0.7857;
mu_0=1.885;
mu_INF=0.05320;
mu_CROSS=DPM_MU(p);
aux=pow(SR,m);
return mu_CROSS;
blackmask is offline   Reply With Quote
Old   May 17, 2013, 08:29
Barbara
Hello Blackmask,
Thank you for your quick response and your advice. I tried it out but it did not work, the same error occurs at the same iteration step.
Maybe there is something wrong with the usage of the macro DPM_MU(p)? I tried to vary the posibilietes to include this (still I am not sure if I need it) but nothing changes...:-(
Old   May 17, 2013, 09:31
I did not see that your error occurs after several iterations. Did the calculation tends to diverge before the error occurred?
Old   May 17, 2013, 13:28
Barbara
No, not at all...it neither brings any messages of divergences. The residuals are normal and tend to fall than to rise.
Old   May 20, 2013, 04:16
Barbara
But as I found out, before this error occurs, there is brought a message "Advancing DPM injection..." and then the error occurs. So I guess it has directly to do with the particle model and with the code. When I set the viscosity to a constant value it works.
Has anyone any ideas?
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Problem UDF for Turbulen viscosity fevi84 Fluent UDF and Scheme Programming 2 June 25, 2017 18:25
Help !! UDF for second phase viscosity. yong FLUENT 2 January 24, 2007 11:11
parallel UDF problem kerem FLUENT 2 June 20, 2006 06:56
Help - UDF for solid shear viscosity nbh2801 FLUENT 0 April 21, 2006 07:49
