UDF temperature profile
Like Tree23Likes
Old   July 12, 2014, 11:24
Mohamed
B.Hamada is on a distinguished road
Originally Posted by ghost82 View Post
Ok, but since we cannot read the future you can only evaluate temperatures at time t and t-deltat and not deltat+t.
Again, start writing some code, someone will help you to go through your code.
Daniele
Thank you brother, i'll try
B.Hamada is offline   Reply With Quote
Old   July 13, 2014, 21:18
Mohamed
Hi Friends
I wrote this code, please can someone tell me if my UDF was correct, and if there are errors, you could fix it.
thank you
PHP Code:
/#include "udf.h"
DEFINE_PROFILE(heatflux_profileti)
face_t f
real It=750;
real H=232000;
real Tam=300;
real Tm=298.6;
real Ul=20;
real Eta=0.16;
real m=2;
real cs=1.4;
real cl=1.8;
real Tpv;
real time;
begin_f_loop(fthread)
Tpv C_T(c,t);
time RP_Get_Real("physical-time-step");
    if(
Tam<Tpv<Tm
F_PROFILE(f,t,i) = Ul*(Tpv*Tam) *time+Eta*It*Time+m*cs*(Tpv-Tam);
    else if(
Tpv=Tm)
F_PROFILE(f,t,i) = Ul*(Tpv*Tam)*time+Eta*It*Time+m*cs*(Tm-Tam)+H;
    else(
Tpv>Tm)
F_PROFILE(f,t,i) = Ul*(Tpv*Tam)*time+Eta*It*Time+m*cs*(Tm-Tam)+H+m*cl*(Tpv-Tm);
end_f_loop(f,thread)
When I compiled my UDF, an error occurred, but I can not fix it.
help me please
error line 16: c: undeclared variable.
Old   July 14, 2014, 03:05
Marco Dc
I-mech is on a distinguished road
Originally Posted by B.Hamada View Post
Hi Friends
thank you
PHP Code:
/#include "udf.h"
face_t f
real It=750;
real H=232000;
real Tam=300;
real Tm=298.6;
real Ul=20;
real Eta=0.16;
real m=2;
real cs=1.4;
real cl=1.8;
real Tpv;
real time;
Tpv C_T(c,t);
    if(
Tam<Tpv<Tm
    else if(
Tpv=Tm)
    else(
Tpv>Tm)
help me please
you have used t in your second line DEFINE_PROFILE(heatflux_profile, t, i)
and then you have used thread in begin_f_loop(f, thread) and in end_f_loop(f,thread).
You have to decide. Use t or thread in both.
Let's try as follow, it should work. I hope
PHP Code:
/#include "udf.h"
face_t f
real It=750;
real H=232000;
real Tam=300;
real Tm=298.6;
real Ul=20;
real Eta=0.16;
real m=2;
real cs=1.4;
real cl=1.8;
real Tpv;
real time;
begin_f_loop(ft)
Tpv C_T(c,t);
    if(
Tam<Tpv<Tm
    else if(
Tpv=Tm)
    else(
Tpv>Tm)
end_f_loop(f,t)
Marco
I-mech is offline   Reply With Quote
Old   July 14, 2014, 08:02
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi Friends
thank you
PHP Code:
/#include "udf.h"
face_t f
real It=750;
real H=232000;
real Tam=300;
real Tm=298.6;
real Ul=20;
real Eta=0.16;
real m=2;
real cs=1.4;
real cl=1.8;
real Tpv;
real time;
Tpv C_T(c,t);
    if(
Tam<Tpv<Tm
    else if(
Tpv=Tm)
    else(
Tpv>Tm)
help me please
your equations look completely different in respect of what you posted before..
You are using c in the C_T(c,t) which is your cell temperature but you are not declaring what is c (as the description of error); you are using c (cell) inside and f (face) loop.
If you want the mean of the temperature of the pcm domain you have to first do a c loop over the pcm domain and calculate the mean temperature, then use the f loop to calculate the boundary profile.
Also this "if(Tam<Tpv<Tm)" should be "if (Tpv>Tam) && (Tpv<Tm)".
And also C langiage is case sensitive: time is different than Time, and you are not declaring what is Time.
"Tpv=Tm" assigns Tm to Tpv: it should be Tpv==Tm.
Daniele
PS: Condition Tam<Tpv<Tm will never be possible because you defined Tm<Tam!!
ghost82 is offline   Reply With Quote
Old   July 14, 2014, 17:48
Mohamed
Hi
I changed the equation for the heat flux exerted on the pvhotovoltaique PANEL, an attached image shows the equation
Old   July 17, 2014, 16:55
Mohamed
HTML Code:
#include "udf.h"
DEFINE_PROFILE(heatflux_profile, t, F, i)
face_t f;
real It=750;
real H=232000;
real Tam=300;
real Tm=298.6;
real Ul=20;
real Eta=0.16;
real m=2;
real cs=1.4;
real cl=1.8;
real temp;
temp = F_T(f,t);
real Time;
Time = RP_Get_Real("physical-time-step");
begin_f_loop(f, t)
    if((temp>Tam) && (temp<Tm)
           F_PROFILE(f,t,i) = Ul*(temp*Tam) *time+Eta*It*Time+m*cs*(temp-Tam);
    else if(temp==Tm)
           F_PROFILE(f,t,i) = Ul*(temp*Tam)*time+Eta*It*Time+m*cs*(Tm-Tam)+H;
    else(temp>Tm)
           F_PROFILE(f,t,i) = Ul*(temp*Tam)*time+Eta*It*Time+m*cs*(Tm-Tam)+H+m*cl*(temp-Tm);
end_f_loop(f,t)
Old   July 18, 2014, 07:16
David
GM_XIII is on a distinguished road
Do you keep getting the same error?
GM_XIII is offline   Reply With Quote
Old   July 18, 2014, 12:16
Mohamed
Hi
Yes the same error.
Old   June 21, 2015, 03:08
Shane
sircorp is on a distinguished road
Originally Posted by flotus1 View Post
Since you refuse to be more descriptive, I have to make some assumptions
With "degrees" you mean °C, so I change the temperature variation from 298K-323K.
The x-axis coincides with the axis of the cylinder and the y-axis is from "bottom" to "top".
Thus the temperature varies linearly with the y-axis, with the highest temperature at the greatest positive y-extent of the surface.
#include "udf.h"
DEFINE_PROFILE(temp_linear, thread, position)
real x[ND_ND];
face_t f;
real tmin, tmax, d;
tmin = 298.0;
tmax = 323.0;
d = 0.47;
      F_CENTROID(x,f,thread);
      F_PROFILE(f, thread, position) = (tmin+tmax)/2.0 + (tmax-tmin)/d*x[1];
  end_f_loop(f, thread)
Is "d" a constant or a diameter of the pipe who surface temperature we are trying to create a profile. In case irregular geometry it is better to put d = 1( i mean avoid "d" altogether ( default d= 1))
Thanks
Shane
sircorp is offline   Reply With Quote
Old   June 21, 2015, 10:47
Ericson
Ericson is on a distinguished road
Need help!!
i got this message when i'm trying to compile my udf
can anyone solve this error message?
Ericson is offline   Reply With Quote
Old   June 22, 2015, 04:01
pakk will become famous soon enough
Yes. Look at you code, and check lines 3, 4 and 11, something is wrong there.
pakk is offline   Reply With Quote
Old   June 22, 2015, 08:57
Ericson
This is my code, i don't know what is wrong here..
can you find the mistakes sir?
File Type: c udf.c (298 Bytes, 12 views)
Old   June 22, 2015, 08:59
Ericson
I'm trying to make code for rolling motion of ship..
Old   June 22, 2015, 09:19
Yes I can, and I can show you how. Just read the error messages!
The first error you get says that there are not enough actual parameters in line 3.
So, go ahead, count how many parameters you have (hint: "roll" is a parameter, "dt" is a parameter, "omega" is a parameter, "time" is a parameter and "dtime" is a parameter.) Then look up in the help how many parameters there should be, and you will see something you did wrong.
Old   June 22, 2015, 09:57
Ericson
can you fix my code please?
i can't see what i must doing in help..
Old   June 22, 2015, 10:01
Seriously?
Ok, you are using the macro "DEFINE_CG_MOTION". Look up in the help how many parameters that needs...
Old   June 23, 2015, 01:00
Ericson
i've trying to fixed my codes but when i'm compiling i have another error like this...
Old   June 23, 2015, 02:44
I don't understand why you send me a private message telling that you use notepad.
Using notepad does not prevent you from opening the Fluent manual, and looking at how the macro "DEFINE_CG_MOTION" should be used.
Do you know how to open the Fluent manual?
Do you know how to search in the Fluent manual?
Old   June 23, 2015, 08:31
Ericson
yes i can,, i have seen fluent manual and i have fixed my code..
but when i'm compiling the code again, i got error messages above..
what should i do?
Old   June 23, 2015, 08:49
I am not paranormal, so if you don't show your code I can never know what is wrong.
please help UDF for velocity profile in y-directio raju Fluent UDF and Scheme Programming 6 April 12, 2019 23:21
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
defining temperature profile with UDF mohammadkm Fluent UDF and Scheme Programming 11 July 3, 2013 00:15
UDF temp. profile BC Shashikant FLUENT 0 June 24, 2006 03:16
temperature profile on boundary sivakumar FLUENT 5 November 24, 2002 00:58
