March 9, 2013, 23:45 |
An UDF programming problem
李弘扬
Rep Power: 14 |
I am an UDF new learner. I am dealing with a 2D, transient, two-phase, cavitation problem. I need to capture the interface between the two phase every iteration. And make the heat flux through a part of the interface constant. The following is my code:
#include "udf.h" DEFINE_ADJUST(my_adjust,d) { Domain *mixture_domain; cell_t c; int phase_domain_index=1; int temp1; int temp2; int K; face_t f; Thread *mixture_thread; Thread *subthread=THREAD_SUB_THREAD(mixture_thread,phase_ domain_index); real xc[ND_ND]; thread_loop_c(c,subthread) { C_CENTROID(xc,c,subthread); if(xc[0]<0.04586) { temp=C_T(c,subthread); K=C_K_L(c,subthread); C_T_G(c,subthread)[1]=300000000/K; } } } The code has been interpreted. But FLUENT cannot go on the calculation. Please help me correct the code. Thank you very much!!! |
March 13, 2013, 04:34 |
Paritosh Vasava
Rep Power: 22 |
Did you try compiling the code instead of interpret?
The fluent manual suggest that UDF with DEFINE_ADJUST works only after compiling. |
March 20, 2013, 17:40 |
Rep Power: 13 |
Hi
I will try to help a little bit. First, mixture thread is the thread you should use for your loop. The THREAD_SUB_THREAD have to be inside this looping operation. In this case you give subthread a phase-level thread of a mixture thread which isn't defined. Second, I'm not 100% sure about this, but I think it isn't possible to set a temperature gradient, because it is a derived value in your flow field. At least your looping macro uses the wrong input and you have to loop over the cells in every thread, too. (Domain->Loop Thread-> Loop Cells -> Cell Operations). Check out the UDF Manual about this. However good luck with your solution. Greetings |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
Problem with my udf | july | Fluent UDF and Scheme Programming | 3 | June 20, 2010 06:56 |
problem with udf programming in fluent | saranyasimi | Main CFD Forum | 0 | December 1, 2009 12:19 |
UDF problem | mansha goraya | FLUENT | 0 | October 29, 2007 00:31 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 07:14 |
