UDF Compiling - can't read ..\..\src\xxx_udf.c: No such file or directory |
March 28, 2013, 11:22 |
Willy Bernal
I am trying to build a UDF file, but seems to be working fine when I select it on the Dialog. The output on the screen shows the next. However, the linking process does not occur.
> Deleted old C:\user\Fluent1\libudf\src\libudf\win64\3ddp\libud f.dll 1 file(s) copied. (system "copy "C:\PROGRA~1\ANSYSI~1\v130\fluent"\fluent13.0.0\sr c\makefile_nt.udf "C:\user\Fluent1\libudf\src\libudf\win64\3ddp\make file" ") 1 file(s) copied. (chdir "C:\user\Fluent1\libudf\src\libudf")() (chdir "win64\3ddp")() # Generating udf_names.c because of makefile radiant_3_udf.obj Done. The Process seems to be working ok. It will generate the following folders and files: \libudf\srcradiant_3_udf.c The log file has this output. sed: can't read ..\..\src\radiant_3_udf.c: No such file or directory NMAKE : U1077: 'sed' : return code '0x2' Stop. Is this a compiler issue? does not seem like it. Any ideas? I do not have administrative privileges for this. Need to make sure that that is the problem. Thanks in Advance! |
compiler, fluent 13, nmake, udf |
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 14:22 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
