water sloshing in oscillating tank (problem using udf Define_ZONE_MOTION)
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   April 1, 2013, 01:37
Default water sloshing in oscillating tank (problem using udf Define_ZONE_MOTION)
Sumit Tambe
Tamsu is on a distinguished road
hello everyone,
I am simulating 2D sloshing of water due to oscillatory motion of a square tank. Here is a small description:
model=VOF: Implict, with zonal discretization.
gravity in 'y' dirctn.
Tank: 0.2m x 0.2m sqaure tank, closed walls.
Mesh: structured, finer at the water-air interface.
filled depth: 0.04m
UDF:
#include <udf.h>
DEFINE_ZONE_MOTION(fmotion,omega,axis,origin,veloc ity,time,dtime)
real velocity={0.6282*sin(62.82*time),0.0,0.0};
return;
UDF is hooked up with both of the cell zones.
Walls: moving walls, with relative velocity(adjacent to cell zone) =0 m/s
time-step size=0.0001 s
during calculation x and y velocity residuals are remaining almost constant until I reduce momentum URF to 0.001, then after the solution rapidly converges.
But water remains stationary as before. The free surface orientation does not change with time. even after 1 second of flow time.
Can anybody help me out?
Tamsu is offline   Reply With Quote
Old   April 2, 2013, 06:49
Paritosh Vasava
vasava will become famous soon enough
1. Is there a space in 'DEFINE_ZONE_MOTION(fmotion,omega,axis,origin,veloc ity,time,dtime)' or just a typo?
2. It is possible that 1 sec is too short time to notice sloshing, try bit longer simulation.
vasava is offline   Reply With Quote
Old   April 2, 2013, 08:00
Sumit Tambe
Yeah, its a typo.
Time is surely not an issue. Instead of trying with a moving mesh, I varied a body force. Its giving good results even for small simulation time. Just that you wont see the mesh moving. but Its fairly sufficient for the analysis.
Old   April 2, 2013, 08:18
Paritosh Vasava
You said it first! I was just going to suggest that. So is everything fine now?
Old   April 2, 2013, 10:46
Sumit Tambe
Yup!! everything is great!
Old   November 9, 2013, 09:24
Default sloshing
Puneet
puneetnema is on a distinguished road
Originally Posted by Tamsu View Post
hello everyone,
filled depth: 0.04m
UDF:
#include <udf.h>
return;
sir i m facing same problems...how did u rectify those..plz help me out
puneetnema is offline   Reply With Quote
Old   May 16, 2014, 08:42
samwize is on a distinguished road
Sumit,
Can you please let me know how to go about solving this problem
Thanks,Samwize
samwize is offline   Reply With Quote
Old   November 23, 2021, 06:52
venu madhav
venu1591 is on a distinguished road
Yeah, its a typo.
Hi Tamsu,
How did you use an oscillating body force in FLUENT? Did you use UDF or is there a better way to do so?
Thanks,
Venu
venu1591 is offline   Reply With Quote
Old   November 24, 2021, 00:11
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
to apply gravity you may use momentum source term
to make it transient you may use transient profile or UDF
and may be expression now (which should be checked)
venu1591 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
define_zone_motion, lateral excitation, sloshing, udf
sloshing in tank manoj kumar FLUENT 7 July 30, 2011 05:53
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 12:34
Udf for sloshing problem D.Martelli Fluent UDF and Scheme Programming 0 December 9, 2009 11:21
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
