How to write UDF to achieve phase chang
Old   May 6, 2013, 08:43
Default How to write UDF to achieve phase chang
dengjiajia
dunga82 is on a distinguished road
I want to write UDF that can achieve the phase change such as boiling, but I must use the Eularien mutiphase model and tubulent. I try to add the UDF than is successful in VOF, miture and Eluraien laminar model to the fluent, but it doesn't work on Eularien tubulent model.
So, who can help me find a UDF that can achieve in Eularien tubulent model?
dunga82 is offline   Reply With Quote
Old   May 6, 2013, 10:49
Bin
Chan Hiang Bin
Bin is on a distinguished road
Hi dunga82,
How you write the UDF that success in laminar flow? I currently doing problem that involved phase changes as well.
Thank you for the helps in advance.
Regards,
Bin
Bin is offline   Reply With Quote
Old   May 8, 2013, 22:16
Shashank
shashank312 is on a distinguished road
Hey dunga82,
Could you share your code on VOF laminar phase change? I am having trouble with access-violation errors because of the DEFINE_ADJUST macro.
Thanks.
shashank312 is offline   Reply With Quote
how to write a UDF to input temperature at nodes as I.C? tensun Fluent UDF and Scheme Programming 2 July 21, 2013 10:44
write UDF results to .txt file C.C Fluent UDF and Scheme Programming 0 January 24, 2013 09:20
Write UDF to add a sink term for PEM fuel cell design kitrax Fluent UDF and Scheme Programming 0 March 15, 2012 04:56
multiphase UDF, variables for phase velocities Kerem FLUENT 4 March 27, 2006 08:20
UDF to write interp files Karl FLUENT 6 February 7, 2002 12:10
