source term UDF- gettnig "error"
Like Tree1Likes
  • 1 Post By blackmask
Old   May 22, 2013, 14:18
Default source term UDF- gettnig "error"
Moha
ahvz is on a distinguished road
Hi to all,
I am trying to define a source term as a function of "CURRENT TEMPERATURE" as its a transient analysis.
indeed, this source term for a specific range of temperature will be applied when its between upper and lower temperature defined).
but I gave this error :
Error: CURRENT_TEMPERATURE: undeclared variable"
while the temperature profile already defined by another code before reading the current code. so shouldn't it recognize by Fluent ?
best regards,
start the code:
UDF that simulates M-source specifying a temperature-
dependent
#include "udf.h"
#define T_upper 290.8833
#define T_lower 296.7833
DEFINE_SOURCE(cell_source, cell, thread,SRC_ON)
real source;
real temp = CURRENT_TEMPERATURE;
static int SRC_ON=1;
if(temp>=T_upper)
SRC_ON = 0;
if (temp < T_lower)
SRC_ON = 1;
if(SRC_ON)
source=(-0.02*pow(temp,3.))+(18.131*pow(temp,2.))-(5464.6*pow(temp,1.))+548332;
} else {
source = 0.
return source;
ahvz is offline   Reply With Quote
Old   May 22, 2013, 22:05
blackmask will become famous soon enough
   dependent
#include "udf.h"
DEFINE_SOURCE(cell_source, cell, thread,eqn)
real source;
real temp;
Domain* domain;
real xc[ND_ND];
real xdist = 1.E10;
cell_t  c;
thread *t;
static cell_t c0;
static thread *t0;
static int FOUND = 0;
if (! FOUND) {
FOUND = 1;
domain = Get_Domain(1);
thread_loop_c(t, domain) {
begin_c_loop(c,t)
C_CENTROID(xc, c, t);
 if ( NV_MAG(xc) < xdist ) {
xdist = NV_MAG(xc);
c0 = c;
t0 = t;
end_c_loop(c,t)
temp = C_T(c0, t0);
if(temp>=T_upper)
SRC_ON = 0;
if (temp < T_lower)
SRC_ON = 1;
if(SRC_ON)
} else {
source = 0.
return source;
blackmask is offline   Reply With Quote
Old   May 23, 2013, 04:46
Moha
thank you very much for the code!
why this code have error ?
as I remember, the "parse error" belongs to the parenthesis but here it seems different. would you please explain a little about this error?
regards,
dependent
#include "udf.h"
real source;
real temp;
static int SRC_ON=1; < --------parse error.
Domain* domain; parse error.
real xc[ND_ND]; parse error.
real xdist = 1.E10; parse error.
cell_t c; parse error.
thread *t; < -------- t: undeclared variable
static cell_t c0;
static thread *t0;
if (! FOUND) {
FOUND = 1;
begin_c_loop(c,t)
xdist = NV_MAG(xc);
c0 = c;
t0 = t;
end_c_loop(c,t)
temp = C_T(c0, t0);
if(temp>=T_upper)
SRC_ON = 0;
if (temp < T_lower)
SRC_ON = 1;
if(SRC_ON)
} else {
source = 0.
return source;
Old   May 23, 2013, 05:40
Some minor syntax error exist in the last post. I have corrected those errors so that the following should be complied.
#include "udf.h"
DEFINE_SOURCE(cell_source, cell, thread, dS, eqn)
    real source;
    real temp;
    Domain* domain;
    real xc[ND_ND];
    real xdist = 1.E10;
    cell_t  c;
    Thread *t;
    static cell_t c0;
    static Thread *t0;
    if (! FOUND) {
        FOUND = 1;
            begin_c_loop(c,t)
                 xdist = NV_MAG(xc);
                 c0 = c;
                 t0 = t;
             end_c_loop(c,t)
    temp = C_T(c0, t0);
    if(temp>=T_upper)
        SRC_ON = 0;
    if (temp < T_lower)
        SRC_ON = 1;
    if(SRC_ON)
    } else {
        source = 0.;
    dS[eqn] = 0.;
    return source;
Old   May 23, 2013, 06:19
Moha
still same error appear (parse error) when I interrupting the code for the below lines of the code.
real source; parse error
real temp; parse error
static int SRC_ON=1; parse error
Thread *t; parse error
static cell_t c0; parse error
static Thread *t0; parse error
static int FOUND = 0; FOUND: undeclared variable
when/why parse error usually appear ?
regards,
Old   May 23, 2013, 06:30
Attach you udf file, please.
Old   May 23, 2013, 06:32
Moha
Please find the attached file.
regards,
Old   May 23, 2013, 06:35
Remove the comments and try again.
Old   May 23, 2013, 06:39
Moha
I did, but still same errors.
Old   May 23, 2013, 06:51
I noticed that the administrator updated the forum rules and obviously we belong to the group who do not know how to behave in a forum. This will be my last post in this thread if no additional requirement other than syntax correct. I have tested the code in the #4 post. Will you please literally copy the code in #4 post in this thread? That will save us a lot of time.
Old   May 23, 2013, 07:13
Moha
the below code is a copy of the code presented in threat #4, and corresponding errors are highlighted.
#include "udf.h"
    real source;
    real temp;
    static int SRC_ON=1;         (parse error)
    Domain* domain;(parse error)
    real xc[ND_ND];(parse error)
    real xdist = 1.E10;(parse error)
    cell_t  c;(parse error)
    Thread *t;(parse error)
    static cell_t c0;(parse error)
    static Thread *t0;(parse error)
    static int FOUND = 0;(parse error)
    if (! FOUND) {(FOUND: undeclared variable)
        FOUND = 1;
            begin_c_loop(c,t)
                 xdist = NV_MAG(xc);
                 c0 = c;
                 t0 = t;
             end_c_loop(c,t)
    temp = C_T(c0, t0);
    if(temp>=T_upper)
        SRC_ON = 0;
    if (temp < T_lower)
        SRC_ON = 1;
    if(SRC_ON)
    } else {
        source = 0.;
    dS[eqn] = 0.;
    return source;
Old   May 23, 2013, 07:42
(1) Compile rather than interpret the udf source file.
(2) Post the message displayed in fluent tui / terminal / log file. Do not try to interpret the error/warning message yourself. It could be misleading.
ahvz likes this.
Old   May 23, 2013, 19:12
Moha
According to your recommendation, the code was add into compiler but it can't be "load" its impossible to attach the .log file regard to the error appearance.
As the file can not be attach to this threat (the reason is not clear to me) anyway, I just copy/paste the content of the file here :
HTML Code:
Error [cortex] [time 5/23/13 23:49:25] The UDF library you are trying to load (C:\Users\Mohammad\Desktop\Solidwork-ANSYS-FLUENT\3Dbox-workbench_files\dp0\FFF-10\Fluent\Solidwork-ANSYS-FLUENT) is not compiled for 3d on the current platform (win64).
The system cannot find the path specified.
C:\Users\Mohammad\Desktop\Solidwork-ANSYS-FLUENT\3Dbox-workbench_files\dp0\FFF-10\Fluent\C:\Users\Mohammad\Desktop\Solidwork-ANSYS-FLUENT\3Dbox-workbench_files\dp0\FFF-10\Fluent\Solidwork-ANSYS-FLUENT\win64\3d\libudf.dll
regards,
Old   May 23, 2013, 20:26
You can find some clue from this thread(http://www.cfd-online.com/Forums/flu...amic-mesh.html). I do not know windows much so I am not be able to help you. The wired thing I heard from one thread is that they also invoke the 'sed' command from the 'makefile' for windows distribution. If you find 'sed' in the libudf/src directory, then maybe you need to install the 'sed.exe' utility. Now I am a bit concerned whether you have compiled your udf successfully or not.
Old   May 24, 2013, 00:20
Shashank
shashank312 is on a distinguished road
I think the above problem occurs if you haven't installed Microsoft Visual C++.
shashank312 is offline   Reply With Quote
Old   May 28, 2013, 05:59
Moha
I have installed it. but I still have problem to compile UDF...
Old   May 28, 2013, 09:34
Shashank
Are your path variables properly set?
Old   May 28, 2013, 10:50
Moha
As I tried many proposals and now I am not sure if I have every things correctly.
would you please explain more how to do that properly ?
for now, my error belongs to the link problem :attached file (I change the type to .txt regarding to attach problem file)
LINK : fatal error LNK1181: cannot open input file 'm.C'
regards,
File Type: txt log.txt (392 Bytes, 5 views)
Old   May 29, 2013, 12:46
Moha
thank you for the supports
Finally, the .c file compiled and loaded !
as I tried so many proposals, I have to bring the workable method here (even though its for specific OS)
win 7 x64 bit
first the UDF file should be saved as (name).c =====.>(important not capital c)
then with only SDK command prompt (preferred Install a Software Development Kit (SKD) for 64bit systems. This may be the difference between 32bit and 64bit systems. I have used the .NET Framework 2.0 Software Development Kit (SDK) (x64) from 2006 [5] ) in my PC other versions 7.0 and 7.1 even work.
Start FLUENT from the SDK command prompt. Do not use the Visual Studio command prompt, use the SDK command prompt! Go to the directory your case is in and type 'fluent'.
regards,
UDF for energy source term engloly Fluent UDF and Scheme Programming 11 June 25, 2017 06:05
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
UDF Source Term Christian FLUENT 4 August 1, 2009 05:53
The source term of UDF summer FLUENT 0 August 24, 2006 17:44
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
