RE: UDF int expectedchip-exec type error
Like Tree2Likes
  • 1 Post By yashganatra
  • 1 Post By AlexanderZ
Old   June 7, 2013, 06:41
Default RE: UDF int expectedchip-exec type error
Yash Ganatra
yashganatra is on a distinguished road
Attached is the UDF - I have combined two UDF's from the tutorial regarding giving an inlet velocity profile and a source term in the X-momentum eqn. Separately they are working fine but when I combine them by interpreting, this the error:
Error
chip-exec: combined: wrong return type:
float udf function expectedchip-exec: combined: argument 1:
incorrect type (38): int expectedchip-exec: combined:
argument 2: incorrect type (5): pointer expectedchip-exec: combined:
argument 3: incorrect type (0): pointer expectedchip-exec: combined:
argument 4: incorrect type (0): int expected
Also I have a fundamental doubt:
In a UDF like this where I have inlet velocity variable and also a source term, I will hook the UDF in Inlet velocity and Sources ; the same UDF is attached to inlet velocity and momentum eqn ; but how does FLUENT distinguish between the application of these two? What if it confuses between the condition?
I hope I have made my point clear. I am a beginner and learning about UDF
Thanks,
Yash
File Type: c combined.c (659 Bytes, 24 views)
yashganatra is offline   Reply With Quote
Old   June 7, 2013, 08:33
Yash Ganatra
I got the solution after scouting around earlier threads.
Yash
dagang likes this.
Old   April 15, 2015, 19:42
Default having the same problem
HPUR is on a distinguished road
I'm getting the same error .Could you please let me know how did you figure out to eliminate this error?
Thanks
HPUR is offline   Reply With Quote
Old   January 5, 2020, 05:25
dagang is on a distinguished road
Yash
Can you share your solution with us? I have the same problem.Thanks.
dagang is offline   Reply With Quote
Old   January 5, 2020, 21:51
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
in code above was
source = dS[eqn] = 0. ;
to be
{source = 0. ;
dS[eqn] = 0. ;}
dagang likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
error udf, fluent - udf, source terms, udf and programming
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
