deviation and Gradients
Like Tree1Likes
  • 1 Post By blackmask
Old   August 5, 2013, 16:22
Default deviation and Gradients
Stephan Langenberg
Jim87 is on a distinguished road
In order to realize an equation (attached) I need to catch up some deviations (pressure Gradient and temperature Gradient).
- What is the best way to include deviations in a UDF? Should I use the Gradient Macro or is there a better way to use deviations?
- In my opinion I need a pointer on the deviations, are these pointer identic with the Macro-NAme (for examplecan I use C_P_G as pointer and function variable for the pressure deviation?)
- As a hint for me, Might this work? A= B*pressure'
double A 0.0;
double B 0.0;
//variables
pressure' = C_P_G(c,t);
Greetings,
Jim
Jim87 is offline   Reply With Quote
Old   August 7, 2013, 08:18
Stephan Langenberg
I tried a small UDF (only to catch up the gradient of temperature und build an equation with it)
I think I have to add something or activate a hook in the solver system, but I don't get the problem fixed. Tried #include "mem.h", but this seems not to be the missing step.
Can someone please give my a feedback?
#include "udf.h"
DEFINE_PROPERTY(test_Gradienten,c,t)
Standard UDF Befehle
double Rho = 0.0;
double gradient = 0.0;
double s1 = 5;
Variablen aufrufen
gradient = C_T_G(c,t)[1];
Zeiger Druck und Temperatur
Rho = 1 + gradient * s1;
return Rho;
C:\PROGRA~1\ANSYSI~1\v145\fluent\fluent14.5.0\win6 4\3ddp\fl1450s.exe received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Old   August 8, 2013, 07:42
blackmask will become famous soon enough
Ensure that the pointer is not null. The macro might be invoked before the temperate gradient is calculated.
#include "udf.h"
double Rho = 0.0;
double s1 = 5;
Variablen aufrufen
if (NNULLP(THREAD_STORAGE(t, SV_T_G)))
return Rho;
Jim87 likes this.
blackmask is offline   Reply With Quote
Old   August 9, 2013, 06:44
Stephan Langenberg
thank you. This one line fixed the UDF.
