July 29, 2013, 02:37 |
Compilation error
uday
Rep Power: 12 |
Hi im trying to model unsteady heat transfer from wall with the following udf:
#include "udf.h" DEFINE_PROFILE(unsteady_heat, thread, position) { face_t f; begin_f_loop(f, thread) { real t = RP_Get_Real("flow-time"); F_PROFILE(f, thread, position) = 0.01072*(300.0+(1527.84*doubleexp(double(0.0854*t) ))); } end_f_loop(f, thread) } However I am getting syntax error while compiling. Can anybody help me out? thanks in advance. |
July 29, 2013, 02:53 |
Paritosh Vasava
Rep Power: 22 |
You have not declared 'doubleexp'. Also use of type double within the code may not be valid.
July 29, 2013, 03:34 |
uday
Rep Power: 12 |
hi thanks for the reply.
However "double exp (double x)" stands for the mathematical function exp(x) as defined under mathematical functions in udf help section. does the error lie somewhere else? please help. |
July 29, 2013, 05:15 |
Paritosh Vasava
Rep Power: 22 |
When I try to compile it says that there is a ')' is missing. I strongly suspect that it is because of the type declaration with in the statement.
I dont have fluent license for couple of hours. I will check again and get back to you. |
July 29, 2013, 08:46 |
Paritosh Vasava
Rep Power: 22 |
As I said earlier the error is in the declaration. Yes "double exp (double x)" stands for the mathematical function exp(x) but that doen not mean that you can use it as it is inside a statement.
Try this one, it works: #include "udf.h" DEFINE_PROFILE(unsteady_heat, thread, position) { face_t f; double t1, t2; real t = CURRENT_TIME; begin_f_loop(f, thread) { real t = RP_Get_Real("flow-time"); t1 = 0.0854*t; t2 = exp(t1); F_PROFILE(f, thread, position) = 0.01072*(300.0+(1527.84*t2)); } end_f_loop(f, thread) } |
July 30, 2013, 03:31 |
uday
Rep Power: 12 |
Thanks Vasava....
It works fine now... |
syntax error, unsteady heat transfer |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
