UDF: Using Data Points for material characteristics?
Old   July 31, 2013, 10:12
Default UDF: Using Data Points for material characteristics?
Stephan Langenberg
Jim87 is on a distinguished road
Hallo,
Ansys Fluent has a lot of possibilities to build material characteristics, but these are usual temperature dependant functions are approximations.
In my case I need a material characteristic dependanat on temperature and pressure and would like to import experimental data sheets from an measurement. (a list of the density influenced by temperature and pressure).
Is there is a possibility to establish material characteristics by a list or register function?
for example that a material characteristic dependant on temperature and pressure is set by listing some values?
Density Temperatur Pressure
1.01 300 3e+07
1.02 300 3.5e+07
0.99 500 3.5e+07
Maybe someone has experience in this?
Jim87 is offline   Reply With Quote
fluent udf, saving data in udf mohsen zendehbad Fluent UDF and Scheme Programming 15 June 13, 2017 23:23
Assigning data points as boundary condition using fluent ripong Fluent UDF and Scheme Programming 2 August 31, 2012 05:03
display data in UDF fleure_Jasmin Fluent UDF and Scheme Programming 0 May 27, 2012 11:11
Use of Experimental Data in fluent using UDF anvitaa.sharma FLUENT 2 February 18, 2010 10:46
Saving data from monitoring points Astrid CFX 3 April 10, 2002 04:55
