Error: CAR: invalid argument [1]: wrong type [not a pair]???
Like Tree1Likes
  • 1 Post By fox000002
Old   August 22, 2009, 07:21
Default Error: CAR: invalid argument [1]: wrong type [not a pair]???
Paul
Paulus is on a distinguished road
What does this error mean?
Paulus is offline   Reply With Quote
Old   March 13, 2010, 13:39
Default same problem
amirbahador
amirbahador is on a distinguished road
HI dude
I have same problem now ....have u fix it by now ...pls help me to solve my problem
amirbahador is offline   Reply With Quote
Old   April 27, 2010, 07:53
izumi11 is on a distinguished road
Ok you need to explain which function call gives you this. Usually this comes from the scheme interpreter. It means that some scheme function received the wrong arguments.
Please explain more.
izumi11 is offline   Reply With Quote
Old   April 28, 2010, 11:07
fox000002's Avatar
fox000002 is on a distinguished road
(car "xxx") ; When using 'car', its argument should be a list.
shen qi jing ling likes this.
fox000002 is offline   Reply With Quote
Old   March 30, 2011, 15:19
Jeremy Allen
Jallen13a is on a distinguished road
I received this same error message when trying to add source and sink terms to separate cell zones. It was confusing me because sometimes I would receive the error and sometimes I wouldn't.
I talked with ANSYS customer support today and they told me that it had to do with problems with the code when using the GUI. Their suggestion was to close Fluent and start it up again.
I had already tried this once and it didn't help. However, at the suggestion of the customer service rep I tried it again and it worked the 2nd time. I was able to add the source and sink terms and did not receive an error.
I don't know if this will help for every case where this error message appears, but it's worth a try.
Jallen13a is offline   Reply With Quote
Old   October 28, 2012, 05:10
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I also received this error for a double periodic domain, when trying to plot contour or define periodic planes; my domain is a slice of a tube translational periodic in z direction and rotational periodic around z axis.
However I have no problems in postprocessing with CFD-POST.
ghost82 is offline   Reply With Quote
Old   October 28, 2012, 09:01
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I don't get any problem while defining the periodic planes or contour plot on periodic boundaries.
Far is offline   Reply With Quote
Old   August 30, 2013, 06:28
aditya chiliveri
adityachiliveri is on a distinguished road
Originally Posted by amirbahador View Post
HI dude
Even I had the same error message displayed.
Closing the fluent and restarting and importing the case/data/mesh file fixed the issue for me.
adityachiliveri is offline   Reply With Quote
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
Parallel FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 1 July 28, 2006 12:48
error: CDR: invalid argument [1]: wrong type Marc FLUENT 0 July 24, 2006 05:59
