October 10, 2013, 06:37 |
surface reaction UDF-compile
a
Rep Power: 16 |
Hi
I have defined a surface reaction UDF I have compiled and hooked this UDF correctly, but I dont know where can I find my reactions in fluent, in the material panel or species transport panel, the parameters of surface reactions are in the default state, Is there any idea? |
October 12, 2013, 16:18 |
A-A Azarafza
Rep Power: 14 |
Hey!
Reactions are defined as a source term in species transport equations. I suppose that you should look for it in the pertinent zone (in your case wall due to surface reaction) and under source tab and for the relevant species.
Regard yours |
October 20, 2013, 15:17 |
a
Rep Power: 16 |
Thanks,
But There is not any source in the source tab, |
October 20, 2013, 22:47 |
Stuart Buckingham
Rep Power: 25 |
Hi, You must setup your reactions by enabling the species transport model. Once species transport is selected, you can then enable volumetric reactions, and then wall surface reactions. Then in your mixture material, you can edit your reaction. Hook your UDF by going to Define menu > User > User Defined Function Hooks. Make sure you also enable the Mechanism for the mixture.
Stu |
October 25, 2013, 17:17 |
#5 | |
a
Rep Power: 16 |
Thanks for your comment, I have defined the activation energy(E) and pre-exponential factor(k0) in the udf, but after hooking the udf, the rection parameters in the species/surface reaction/reaction menu, the reaction parameters (E and K0) are under default conditions, (for example E=8e11) I dont know where is my UDF data? |
Defining reaction rate with multiple surface reaction | Fred Marias | FLUENT | 1 | September 12, 2013 04:56 |
Unit of rate in udf of a surface reaction | borhan_sd@yahoo.com | Fluent UDF and Scheme Programming | 0 | June 11, 2013 03:28 |
UDF macros for surface reaction | borhan_sd@yahoo.com | Fluent UDF and Scheme Programming | 0 | June 6, 2013 08:57 |
particle surface reaction | lili | FLUENT | 0 | August 5, 2012 02:17 |
udf for partical surface reaction | blaid | FLUENT | 0 | April 25, 2011 07:24 |
