new-parameter :surface integral of velocity
Old   December 5, 2013, 19:18
Default new-parameter :surface integral of velocity
Negin Nazarian
nenazarian is on a distinguished road
I need to define air exchange rate in each node by integrating y and z velocity on a face surface. For that purpose, I have wrote the following UDF
/* UDF for computing the magnitude of ACH */
#include "udf.h"
DEFINE_EXECUTE_AT_END(ach,f,t,d,dt,w,v)
face_t f; Thread *t; Domain *d; real NV_VEC(A);
/* Integrate w velocity. */
real flow_time = CURRENT_TIME;
real dt = CURRENT_TIMESTEP;
real w= F_W(f,t) ; real v= F_V(f,t) ;
real sum_ACHt_in=0.; real sum_ACHs_in=0.;
real sum_ACHt_out=0.; real sum_ACHs_out=0.;
real ACHt_in, ACHt_out, ACHt_it, ACHt_ot;
real ACHs_in, ACHs_out, ACHs_it, ACHs_ot;
/*cell_t c;*/
d = Get_Domain(1); /* mixture domain if multiphase */
thread_loop_f(t,d)
begin_f_loop(f,t)
if (w<=0)
ACHt_in= w * NV_MAG(A)/16 ;
sum_ACHt_in +=ACHt_in;
ACHt_it=sum_ACHt_in*dt/flow_time;
else
ACHt_out= w * NV_MAG(A)/16;
sum_ACHt_out +=ACHt_out;
ACHt_ot=sum_ACHt_out*dt/flow_time;
if (v<=0)
ACHs_in= v * NV_MAG(A)/16 ;
sum_ACHs_in +=ACHs_in;
ACHs_it=sum_ACHs_in*dt/flow_time;
else
ACHs_out= v * NV_MAG(A)/16;
sum_ACHs_out +=ACHs_out;
ACHs_ot=sum_ACHs_out*dt/flow_time;
end_f_loop(c,t)
However, I am confused on how to access and output this parameter in each node after calculation.
Also, is it possible to use sampling option for time averaging this parameter?
I would appreciate your help.
Cheers,
Negin
nenazarian is offline   Reply With Quote
Old   December 6, 2013, 02:16
pakk will become famous soon enough
Use user defined memories (UDM) for your variables.
For example, if you want to access ACHs_ot, replace it by F_UDMI(f,t,0).
pakk is offline   Reply With Quote
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
Text command for report surface integral jbjiang FLUENT 0 November 2, 2011 14:54
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Surface Integral - Mass Flow Rate Venkatesh V FLUENT 3 October 10, 2008 16:18
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
