UDF for effective thermal conductivity in porous media
Old   February 24, 2014, 01:22
Unhappy UDF for effective thermal conductivity in porous media
dotapro is on a distinguished road
Hi all,
I am trying to modify effective thermal conductivity in porous media as
default keff used by fluent is not suitable for porosity of material larger than 0.9. My modified formula is where
keff (effective thermal conductivity) = 1/3*(1-e(porosity)*ks (solid thermal conductivity)
Can you give some hints of writing this code in UDF fluent? Please help me out......
My code is incorrect when loading in fluent:
#include "udf.h"
#include "mem.h"
DEFINE_PROPERTY (cell_keff,c,t)
{ real porosity=0.9;
real k_s=400;
real my_keff=C_K_EFF(c,t,prt);
my_keff=k_s/3*(1-porosity);
return my_keff;
dotapro is offline   Reply With Quote
Old   February 24, 2014, 05:37
pakk will become famous soon enough
"prt" in your code is not defined. You should put the turbulent Prandtl number there, somehow.
pakk is offline   Reply With Quote
Old   February 24, 2014, 06:50
I'm actually using laminar flow. Can I ignore the term prt by putting it as C_K_EFF(c,t)? Another thing is I notice C_K_EFF(c,t) is a variable for macros. Is it the right way to define?
Old   February 24, 2014, 07:43
Ah, I see you want the thermal conductivity of the solid.
I don't think you should use C_K_EFF(c,t,prt), that has to do with turbulent calculations.
If you wanted to have the thermal conductivity of the fluid, you should have used C_K_L(c,t). But for the solid, I can not find it...
The Fluent manual says (6.2.3.3.1): "
The fluid thermal conductivity k_f and the solid thermal conductivity k_s can be computed via user-defined functions. "
But I can not find which user-defined function you need for solid thermal conductivity...
Old   February 24, 2014, 07:54
Yes, you are right. I having trouble to define macro for solid thermal conductivity where I can't find it in Fluent UDF manual. Plus , I'm not sure that C_K_EFF(c,t) can be set equal to something (my_keff) . Hoping some help will come soon.
Old   February 24, 2014, 08:03
Forget about the C_K_EFF(c,t,prt), it is not related to what you need. That is about averaging out turbulent effects, you want to average out porosity effects. Those are different things.
I found somewhere in mem.h that Fluent uses
MATERIAL_PROP(THREAD_SOLID_MATERIAL(t),PROP_ktc))
to obtain the thermal conductivity of the solid. You could try that. I never used it, so doublecheck any results you get.
Old   February 24, 2014, 08:07
I guess it would look something like this:
#include "udf.h"
  real porosity=0.9;
  real my_keff;
  my_keff=MATERIAL_PROP(THREAD_SOLID_MATERIAL(t),PROP_ktc))/3.0*(1-porosity);
  return my_keff;
I don't know if Fluent will complain about PROP_ktc, and what to do if it complains...
Old   February 24, 2014, 09:00
I try to interpret or compile this code. However, both of these operations were unsuccessful . Any further help of this ?
Old   February 24, 2014, 09:15
In what way were they unsuccessful? Warning? Error? Wrong result?
Old   February 24, 2014, 09:40
It shown that line 7: structure reference not implemented during interpretation.
Old   February 24, 2014, 09:45
That implies that one of the macros is not implemented for interpreting, and you need to compile it. What is the error message when you compile?
Old   February 24, 2014, 09:57
cpp -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/multiport/src" -I. -DUDF
ONFIG_H="<udfconfig-host.h>" "C:\Users\kedy1lkw\Desktop\New folder\cell_keff.c"
Error: C:\\Users\\kedy1lkw\\Desktop\\New folder\\cell_keff.c: line 9: structure reference not implemented
ONFIG_H="<C:/Users/kedy1lkw/AppData/Local/Temp/udfconfig-node0.h>" "C:/Users/kedy1lkw/AppData/Local/Temp/cell_keff.c.0.c"
Error: C:/Users/kedy1lkw/AppData/Local/Temp/cell_keff.c.0.c: line 9: structure reference not implemented
ONFIG_H="<C:/Users/kedy1lkw/AppData/Local/Temp/udfconfig-node1.h>" "C:/Users/kedy1lkw/AppData/Local/Temp/cell_keff.c.1.c"
Error: C:/Users/kedy1lkw/AppData/Local/Temp/cell_keff.c.1.c: line 9: structure reference not implemented
ONFIG_H="<C:/Users/kedy1lkw/AppData/Local/Temp/udfconfig-node2.h>" "C:/Users/kedy1lkw/AppData/Local/Temp/cell_keff.c.2.c"
Error: C:/Users/kedy1lkw/AppData/Local/Temp/cell_keff.c.2.c: line 9: structure reference not implemented
ONFIG_H="<C:/Users/kedy1lkw/AppData/Local/Temp/udfconfig-node3.h>" "C:/Users/kedy1lkw/AppData/Local/Temp/cell_keff.c.3.c"
Error: C:/Users/kedy1lkw/AppData/Local/Temp/cell_keff.c.3.c: line 9: structure reference not implemented
Sorry for spamming.
Old   February 24, 2014, 10:09
This is not spamming
However, it looks like this is the result of interpreting the udf.
You should compile it. (The output in that case starts with "Copied C:\\users\...", I think.)
Old   February 24, 2014, 10:11
Deleted old libudf\ntx86\3ddp_host\libudf.dll
libudf\ntx86\3ddp_node\libudf.dll
1 file(s) copied.
Copied C:\Users\kedy1lkw\Desktop\New folder/C:\Users\kedy1lkw\Desktop\New folder\cell_keff.c to libudf\src
(system "copy "C:\PROGRA~1\ANSYSI~1\v140\fluent"\fluent14.0.0\sr c\makefile_nt.udf "libudf\ntx86\3ddp_host\makefile" ")
1 file(s) copied.
(chdir "libudf")()
(chdir "ntx86\3ddp_host")()
# Generating ud_io1.h
cell_keff.c
# Generating udf_names.c because of makefile cell_keff.obj
udf_names.c
udf_names.c(7) : error C2059: syntax error : '}'
udf_names.c(8) : warning C4034: sizeof returns 0
(system "copy "C:\PROGRA~1\ANSYSI~1\v140\fluent"\fluent14.0.0\sr c\makefile_nt.udf "libudf\ntx86\3ddp_node\makefile" ")
1 file(s) copied.
(chdir "libudf")()
(chdir "ntx86\3ddp_node")()
cell_keff.c
udf_names.c
Done.
This is the result I get when compiling.
Old   February 24, 2014, 10:23
I see that I made a mistake: "PROP_ktc))" should be "PROP_ktc)". Does that help?
The error message you get could be related to line endings. There is a windows way of ending lines, and a linux way of ending lines. You might have to tell your editing program to use the other one.
Old   February 24, 2014, 10:41
Thank you very much for your help. It was successful compiled. So, will default keff in fluent directly replaced by this new keff or I need to hook DEFINE_PROPERTY? If yes,where should I hook it in ?
Old   February 24, 2014, 10:43
In the place where you select your thermal conductivity, you should choose the user defined function (probably named libudf::cell_keff).
Old   February 24, 2014, 10:56
I guess it is the solid thermal conductivity material that I should hook in the udf. Once again, I really appreciate for your time being to help me out. Thank you very much.
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 06:12
Porous media boundary conditions aggie FLUENT 3 June 17, 2012 09:51
Lack of local thermal equilibrium in porous medium Chander CFX 4 March 4, 2012 04:07
UDF for effective thermal conductivity Rashmi FLUENT 1 November 6, 2007 20:08
