Is it possible to define a time-dependent velocity field by UDF
Old   May 3, 2014, 22:25
Question Is it possible to define a time-dependent velocity field by UDF
Zh
adsl17754 is on a distinguished road
Hi all,
I am doing multiphase flow simulation, and I'd like to do a validation case to evaluate the performance of VOF method in FLUENT.
In order to simulate the validation case, the velocity field needs to be defined as:
u=sin^2(πx)sin(2πy)cos(πt/T)
v=cos^2(πy)sin(2πx)cos(πt/T)
How should I define the time-depedent velocity field in FLUENT, is UDF a practical solution ?
Any suggestion is welcome, thanks in advance
adsl17754 is offline   Reply With Quote
multiphase flow, udf code
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 21:13
Problem in UDF time dependent vloumetric heat source eng_yasser_2020 Fluent UDF and Scheme Programming 0 March 30, 2014 08:07
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
time dependent velocity input by user subroutine shohel mahmud Siemens 4 December 18, 2007 11:40
