Reading a file from 32-bit Fluent 15.0 through a UDF for DPM in parallel |
July 11, 2014, 01:52 |
Anthony
Rep Power: 12 |
Hi everyone,
I am currently having a problem reading an external data file with a UDF - DEFINE_DPM_SOURCE. I am combining Fluent with another C program made from my university that contains 32 bit lib files. So I have only managed to get this working on 32-bit fluent. The structure of the program is -Open data file -Read data file -Close data file -Read mass concentrations in fluid -Compare with data file -Create mass source at particle The problem I have is that when I get the message that the UDF cannot read the data file. This only happens in parallel fluent, the program works perfectly in serial however is too slow. I suspect this problem has to do with different nodes opening the data file at the same time. For DPM I have the option of Message Passing or Shared Memory. Shared Memory works but is too slow. Message-passing gives me the error. Hybrid is not available for 32-bit. Is there any way to parallelize this process? Perhaps there is a way to have different nodes read different data files. Thanks in advance |
dpm, fluent, parallel |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
