UDF library not loading on Linux supercomputers
Old   August 1, 2014, 05:26
Default UDF library not loading on Linux supercomputers
tom634 is on a distinguished road
Hello all,
I wrote UDF and it works on Windows 8 and Fluent runned by SDK command prompt.
Then I saved UDF as UNIX file format in order to launch this on supercomputers with Linux. UDF has no any comments starting with "//", but "/* ... */" only.
I receive such error while compiling:
Primitive Error at Node 0: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (lnamd64).
No such file or directory
/home/***/users/***/libudf/lnamd64/3d_node/libudf.so
Any help would be appreciated.
tom634 is offline   Reply With Quote
Old   August 1, 2014, 05:54
pakk will become famous soon enough
I see a contradiction in your post (emphasis mine):
Primitive Error at Node 0: The UDF library you are trying to load (libudf) ...
You don't show the error that shows up during compiling, but during loading. Apparently something went wrong during compilation, so you need to look at the error message given during compilation.
pakk is offline   Reply With Quote
Old   August 1, 2014, 06:18
Problem solved, I had variable y1 in my UDF, I changed it to yy1 and it started to work. Do you know maybe, why with variable y1 it couldn't compile and load?
Old   August 1, 2014, 07:28
No, I don't know that. y1 is not a reserved name, so it should work as well as yy1. The error messages that are shown during compilation could give a hint what went wrong, if you are still interested to find out.
Error: The UDF library you are trying to load is not compiled for 3ddp on the current Whitemast Fluent UDF and Scheme Programming 0 November 21, 2013 06:45
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
error for loading UDF ibuki FLUENT 3 November 7, 2009 04:11
Compiling / Loading UDF Martijn FLUENT 1 December 16, 2008 19:06
Error when loading a shared library rid FLUENT 4 May 29, 2006 14:51
