average temperature of a face
Old   December 6, 2018, 17:12
Question average temperature of a face
on
smukh is on a distinguished road
Hello all,
I am trying to find the average temperature of a face of a cube which is going to be used as inlet temperature to another domain.
I am modelling a cube of stagnant water with inlet boundary condition at 323K. The output of my udf to calculate average temperature is coming zero!
DEFINE_ADJUST(avg_temp,d) /*calc outlet temp average of water*/
real tavg=0.0;
face_t f;
real A[ND_ND];
real area = 0.0;
real area_tot = 0.0;
Thread *t = Lookup_Thread(d,7);
begin_f_loop(f,t)
F_AREA(A,f,t);
area = NV_MAG(A);
area_tot+=area;
tavg+=F_T(f,t)*AREA;
end_f_loop(f,t)
tavg/=area_tot;
printf("avergae temperature of outlet of water is %f\n", tavg);
printf("area total = %f\n", area_tot);
I am new to udf and would appreciate any help with this udf. Thank you!
smukh is offline   Reply With Quote
Old   December 6, 2018, 19:21
obscureed is on a distinguished road
Hi Smukh,
Assuming you've pasted your code accurately, the first error to look at is
because "AREA" is not the same as "area". (C language is case-sensitive.) This should not get past a compiler without some warnings, or maybe errors. Please can you debug this and tell us what happens next? Does your code report a sensible value of area_tot?
This UDF is suitable only for serial Fluent, of course.
I would discourage use of "printf" in UDFs -- "Message" is safer. The difference is possibly small, but not necessarily.
Good luck!
Ed
obscureed is offline   Reply With Quote
Old   December 10, 2018, 15:57
on
Hi Ed,
Thank you for your suggestions. I have successfully resolved it. It worked when I changed from DEFINE_ADJUST to DEFINE_EXCUTE_AT_END and AREA to area. I am not sure why I wasn't getting the value even after changing caps area, it was giving me no error while compiling. But as I did not need values for every iteration I was fine by replacing adjust by at end.
fluent - udf, fluent 18.0, temperature average value, udf code
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
Atributting one face temperature to another face nfspetronilho FLUENT 0 March 28, 2011 12:13
