How to add a source term for parallel computing?
Old   November 13, 2014, 22:06
Default How to add a source term for parallel computing?
Zhao An
8cold8hot is on a distinguished road
My aim is to modify the epsilon equation in the realizable k-epsilon turbulence model.
This is my UDF code:
#include "udf.h"
#include<math.h>
#define C2 1.9	/* The original value of coefficient  */
DEFINE_SOURCE(source_realizable_e, c, t, dS, eqn)
#if !RP_NODE
	real fk = 0.5;	/* The fraction of unresolved kenetic energy to the total */
	real fe = 1.0;	/* The fraction of unresolved rate of dissiptation to the total */
	real source;
	real k_temp = C_K(c,t);
	real e_temp = C_D(c,t);
	source = -(fk/fe-1)*C2*e_temp*e_temp/(k_temp+sqrt(0.001003/998.2*e_temp));
	dS[eqn] = 0.0;
	return source;
#endif
#if RP_NODE
	dS[eqn] = 0.0;
	return 0.0;
#endif
DEFINE_PRANDTL_D(Prandtl_realizable_e, c, t)
#if !RP_NODE
	return 1.2*fk*fk/fe;
#endif
#if RP_NODE
	return 1.2;
#endif
May someone tells me that if I uses the right compilation directive? I think the source term shall be added in the host process, is that right?
Thank you in advance!
8cold8hot is offline   Reply With Quote
Old   November 14, 2014, 08:54
upeksa is on a distinguished road
I don't really know what do you want to do, but try something like this
#include "udf.h"
#include<math.h>
#if !RP_HOST
real source;
dS[eqn] = 0.0;
return source;
#endif
#if !RP_HOST
#endif
I think that the host process has nothing to do with your code.
Cheers
upeksa is offline   Reply With Quote
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
add source term in energy equation chaolian OpenFOAM Programming & Development 4 November 8, 2012 22:22
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Add time dependent Source term libe OpenFOAM Running, Solving & CFD 13 September 23, 2010 09:12
