UDF for Solid.gas and slip velocity in each cell
Like Tree1Likes
  • 1 Post By `e`
Old   January 18, 2016, 01:51
Default UDF for Solid.gas and slip velocity in each cell
Capricorn is on a distinguished road
I have a periodic domain of 0.64x0.64 m with 512x512 grid points. I want to calculate solid velocity,gas velocity and slip velocity in each cell. Can anyone provide UDF for this kind of problem or can anyone guide me a little. Is it even possible?
Capricorn is offline   Reply With Quote
Old   January 18, 2016, 02:03
`e`
`e` is on a distinguished road
Use the cell macros for velocity (C_U, C_V, C_W) and use the thread of the respective phase (solid phase thread, gas phase thread). This question has been asked many times before.
`e` is offline   Reply With Quote
Old   January 18, 2016, 02:12
Thank you for your reply. I was wondering if it is possible in Fluent without UDF??
Old   January 18, 2016, 04:13
`e`
Velocities of the separate phases as well as the mixture are available in the graphics and animations section. Have a read of "Postprocessing for Multiphase Modeling" in the users guide for step by step instructions.
As for the slip velocity between the two phases, have a look through the variables to see if it's listed but otherwise you may need to write a UDF to calculate this velocity difference. Alternatively, you could export the velocities of the two phases and calculate the difference in another program.
Capricorn likes this.
Old   April 7, 2017, 11:45
djing is on a distinguished road
Hello dear colleague ,
Thank you for the help , I would like to ask you if you know any macro which can be used in order to give the values of velocity in each cell center of the inlet boundary condition ?
I will be very grateful if you can help me ...
Thank you .
djing is offline   Reply With Quote
UDF Slip velocity ousegui Fluent UDF and Scheme Programming 0 September 5, 2013 18:37
Fluent UDF for Micro Flow Face Slip Velocity daniel_george_carter Fluent UDF and Scheme Programming 0 May 12, 2013 05:39
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
why boudary slip velocity is so larte using udf cxzhao FLUENT 0 July 4, 2005 00:06
How i can set slip velocity by udf cxzhao FLUENT 0 June 9, 2005 21:34
