F_YI(f,t,i) is creating a problem
Old   May 23, 2009, 06:46
Default F_YI(f,t,i) is creating a problem
itoa
techy is on a distinguished road
Hello everybody,
Here is the UDF
#include "udf.h"
DEFINE_ADJUST(mfrac,domain)
FILE *fp;
float mfrac;
int i = 0;
int zone_ID = 2;
Thread *thread = Lookup_Thread(domain,zone_ID);
face_t f ;
fp = fopen("check.txt","w+");
begin_f_loop(f, thread)
mfrac = F_YI(f,thread,i); /* Here lies the problem */
fprintf(fp,"%d\n",mfrac);
end_f_loop(f, thread)
fclose(fp);
The zone_ID is for a wall.
I have compiled this successfully but it gives ACCESS VIOLATION.
But when i replace F_YI with F_T there is just no problem at all.
F_YI(f,thread,i) is causing this error.
But i am unable to figure out the mistake.
Any help is highly appreciated
techy
techy is offline   Reply With Quote
Old   May 23, 2009, 07:30
itoa
there is a small mistake
as mfrac is defined as float
so i am using
fprintf(fp,"%f\n",mfrac);
but F_YI(f,t,i) is still causing that error
Please help somebody
techy
Old   May 23, 2009, 09:54
Daniel Tanner
Daniel Tanner is on a distinguished road
Not sure what the problem is!
Are you sure F_T is working?
Some quick things to try:
1) Do you need to include "fstream.h"?
2) Should the face_t f; come before the Thread *thread... statement?
3) Remove the file commands (FILE, fp, fprintf, fclose) and see if that helps.
Sorry not sure why it has a problem. Good luck
Daniel Tanner is offline   Reply With Quote
Old   May 24, 2009, 03:10
itoa
yes Daniel F_T is working for sure.
I have tried everything you listed without
any effect.
Please help somebody its a bit urgent.
Techy
Old   May 24, 2009, 06:00
Daniel Tanner
I saw the following on a different forum:
http://university.fluent.com/forum/v...e6ba41c1408da3
It gives some useful bits of info:
"The macros C_YI, F_YI cannot be used while using pdf combustion model.
The species mass fractions can be accessed using the macro Pdf_Yi(c,t,i). When using this macro, please include the library sg_pdf.h in your UDF."
Sorry, I have no other ideas!
Old   May 24, 2009, 11:23
itoa
thanks daniel
but i am only using species transport and nothing
else.
means no benefit from Pdf_Yi
But i am sure this forum is
gonna certainly solve my problem.
Techy
Old   September 3, 2009, 08:03
Byron Smith R J
byronsmith is on a distinguished road
Hai,
The problem is that mfrac is not defined as a array whereas F_YI(c,t,i) generates an arrray of mass fractions of species.
Byron SMith
byronsmith is offline   Reply With Quote
Old   April 2, 2015, 05:36
SJSW is on a distinguished road
I am using Non-premixed model in Ansys 14.0.
The description in
3.2.3.6.1.*Species Fractions Calculations with the Non- and Partially- Premixed Models
says that "... Pdf_Yi(c, t, n) or Pdf_XY(c,t,x,y). The functions are defined in the header file pdf_props.h, which you will need to include in your UDF."
However, I would like to acquire the species fraction on a certain face.
In other cases without Non-premixed model, it should be F_YI(f,t,i).
Could anyone kindly tell me how to get the mass fraction on a face when using Non-premixed model?
Thank you!
SJSW is offline   Reply With Quote
[SOWFA] NREL SOWFA ABLTerrainSolver tutorial problem cico0815 OpenFOAM Community Contributions 36 February 3, 2022 11:54
Problem with building geometry - concentric cylinders Rhoddwen OpenFOAM Pre-Processing 9 December 17, 2014 10:02
[snappyHexMesh] Problem creating patches using snappyheymesh kewsinger OpenFOAM Meshing & Mesh Conversion 3 November 10, 2014 04:48
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Having problem in creating a volume mech in GAMBIT Jake FLUENT 1 April 25, 2008 05:01
