node connectivity of faces on a surfaces using UDF |
April 5, 2015, 23:53 |
Tanjina Afrin
Rep Power: 12 |
Can anybody tell me kindly how can I find the node connectivity of faces on a surfaces using UDF ? All I know is I have to use THREAD_T0,THREAD_T1 macros. Any help will be highly appreciated. Regards, Tanjina |
April 6, 2015, 03:40 |
Rep Power: 18 |
What are you trying to achieve? What do you mean by "node connectivity of faces on a surfaces"? You could use F_C0 and F_C1 to determine the neighboring cells and then loop through the nodes of these cells.
April 6, 2015, 09:48 |
Tanjina Afrin
Rep Power: 12 |
I am trying to find Boussinesq's Momentum coefficient (beta= sum(u^2dA/U^2A)). For that I need to velocity of each node and area of faces. From Fluent I can get velocity of each node and coordinates of nodes, but I don't have any information which node is connected to what for making face. For that reason I am looking for UDF which can give me the node connectivity.
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
Accessing node values using a UDF | Nico | FLUENT | 2 | December 20, 2007 02:50 |
UDF with user created surfaces | Henry Lee | FLUENT | 2 | March 23, 2006 03:24 |
