Segmentation fault during VoF simulation
Old   May 26, 2015, 07:25
Post Segmentation fault during VoF simulation
Rafal
vekh is on a distinguished road
Hello. I have problem with my UDF for 2d case.
I want to get phase level at certain area/volume to define boundary between phases. I wrote simple UDF:
#include <udf.h>
# define r 0.0004
# define x0 0.002
# define y0 0.002
FILE *fout;
DEFINE_SOURCE(my_source, cell, thread, dS, eqn)
  real x[ND_ND];
  real source, xc, yc, prom;
  Thread *tm = THREAD_SUPER_THREAD(thread);
  Thread **pt = THREAD_SUB_THREADS(tm);
  xc=x[0];
  yc=x[1];
  prom = sqrt(pow((xc-(x0)),2));
  if ((prom <= r)&&(C_VOF(cell, pt[1])<1))
    fout=fopen("test.dat","a+");
    fprintf(fout,"%f\n",xc);
    fclose(fout);
source=1;
dS[eqn] =0;
return source;
and I've compiled it. But after first iteration Fluent returns:
Error: received a fatal signal (Segmentation fault).
Function my_source if hooked at Cell Zone/Source Terms/Energy.
I'm quite new to all VoF things so I need some help to start. Thanks in advance!
vekh is offline   Reply With Quote
Old   May 29, 2015, 06:31
`e`
`e` is on a distinguished road
Move the line of code "FILE *fout;" to within the DEFINE_SOURCE macro. If the error persists, try simplifying your code until you determine the problem line (or print text to the screen using Message(); every few lines for debugging).
`e` is offline   Reply With Quote
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
Using VOF model and Lagrangian Multiphase in the same simulation ganesh_krishnan STAR-CCM+ 2 March 17, 2017 01:34
Fluent error: Fatal error (Segmentation fault) shufang FLUENT 2 April 20, 2015 07:06
[OpenFOAM] Segmentation fault with paraFoam and paraview 3.6.1 on Fedora 11 32 and 64 bit nanes ParaView 2 September 11, 2009 09:12
segmentation fault usker Siemens 5 March 5, 2007 23:14
