Modify gravity via UDF
Old   June 22, 2015, 10:37
Default Modify gravity via UDF
witali
bluebelly is on a distinguished road
Hello, i need some help.
I am going to simulate a braking process in a tank, filled with water.
so, therefore i do like to modify the x-gravity in udf. z-gravity is const = -9.81 m/sē.
has anyone an idea how to adress the x-gravity component in the udf?
this is my attempt for the udf:
DEFINE_SOURCE(gx_source, c, t, dS, eqn)
real gx_source;
real time = RP_Get_Real("flow-time");
if (time <= 0.4)
gx_source = 2 * pow(10,-9) * pow(time,4) +
296.74 * pow(time,3) -
178.05 * pow(time,2) +
2.6377 * time -
0.0296;
else if(time <= 3.1)
gx_source = -8.5;
else if(time <= 3.5)
gx_source = -2 * pow(10,-9) * pow(time,4) -
296.74 * pow(time,3) +
2937.8 * pow(time,2) -
9661.7 * pow(time,1) +
10551;
return (gx_source);
many thanks for your help!
bluebelly is offline   Reply With Quote
Old   June 23, 2015, 00:09
Vaze
mvee is on a distinguished road
Hi
The way you are incorportaing gx is correct. It will be body force/source in x momentum equaion. Please check on units of gx. It should be N/m^3.
Best luck
Vaze
mvee is offline   Reply With Quote
Old   June 23, 2015, 01:53
witali
Hello vaze, first of all: thank you for your reply.
I found something like -> C_R(c,t) and C_P(C,t).
How do i have to use it now? I mean, do i have to multiplicate or to divide the gx-source with the C_R(C,t)/C_P(C,t)?
For a testrun i multiplicated it, the visiualisation looked similar to the case, as if i use constant gravity in x direction.
Furthermore, do C_R/C_P depend on the solver i use (pressure-based/density-based)?
Old   June 23, 2015, 04:23
Vaze
Hi
static pressure = rho * gx * z or x distance
Check that C_P corresponds to static pressure or not. if not then deduce it.
all the best,
Vaze
Modify gravity through UDF flotus1 Fluent UDF and Scheme Programming 2 April 12, 2015 05:55
modify a intern variable of Fluent with scheme and UDF fanch33 Fluent UDF and Scheme Programming 3 March 2, 2015 11:01
How can I modify surface reaction using UDF Juun Fluent UDF and Scheme Programming 0 July 28, 2014 09:13
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 06:43
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
