UDF: problem with calculating velocity gradient to normal direction
Old   January 15, 2019, 02:29
Default UDF: problem with calculating velocity gradient to normal direction
Ho Kam Dai
hkdai is on a distinguished road
Recently, I am doing a project related to a pipe structure and I need to do some modification to the surface shear stress, so I need to access the velocity gradient to the normal direction for the purpose.
Since the structure is something similar to a circular pipe, C_V_G(c,t),C_U_G(c,t) and C_W_G(c,t) would not directly access what I need.
Is there any thoughts or suggestion that can help me out of this problem?
hkdai is offline   Reply With Quote
Surface normal velocity BC with zero gradient tangential, cylinder c_dowd OpenFOAM Running, Solving & CFD 0 May 25, 2013 07:22
Multi step transient UDF velocity profile problem William177 FLUENT 1 February 3, 2008 06:47
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
the problem of UDF zzb FLUENT 2 April 5, 2006 05:36
problem for UDF velocity Geremi FLUENT 0 April 19, 2005 02:13
