February 23, 2007, 15:12 |
udf problem about wall heat flux
Hi, I don't know how to define uniform heat flux of wall changing with time. Here is my code. But there is error when I start to iteration. If I should use DEFINE_HEAT_FLUX? Is there an simple example for this micro? Thanks!
#include "udf.h" DEFINE_PROFILE(fluxflow, thread, position) { real tim; face_t f; cell_t c; Thread *t; begin_f_loop(f, thread) { tim=RP_Get_Real("flow-time"); F_PROFILE(f, thread, position)=10tim } end_f_loop(f, thread) } |
February 23, 2007, 16:06 |
Re: udf problem about wall heat flux
I think there are syntax errors. There is no semicolon at the end of F_PROFILE statement.
F_PROFILE(f, thread, position) = 10* time; try this..if its working or not.. shanti |
February 23, 2007, 17:02 |
Hi shanti,
Thanks for your suggestion, I will try later when I finish my class now. |
February 23, 2007, 18:45 |
I have modified the F_PROFILE(f, thread, position)=10*time; Now it can pass interperted. But when I initialize and run, there is error message. I want to give a heat flux changing with time into the sidewall of a solid cylinder. How to define it? Which macro should I use? Thanks. chip-exec: fluxflow: argument 1: incorrect type (36): int expectedchip-exec: fluxflow: argument 2: incorrect type (5): pointer expectedchip-exec: fluxflow: argument 3: incorrect type (0): int expectedchip-exec: fluxflow: argument 4: incorrect type (0): pointer expectedchip-exec: fluxflow: argument 5: incorrect type (0): pointer expectedchip-exec: fluxflow: argument 6: incorrect type (0): pointer expected |
February 23, 2007, 18:54 |
Hi
do you want the flux value to be 10*time? shanti |
February 23, 2007, 18:57 |
Yes. I want the flux is the function of time, and the time is from 0~120 sec.
February 23, 2007, 18:59 |
Can you give the exact relation between the heat flux and the time?
February 23, 2007, 19:06 |
flux=10*time;
That is when time=0, flux=0; time=1, flux=10; time=2, flux=20; . . . . . . time=120,flux=1200; |
February 23, 2007, 19:09 |
#9 |
sorry, I have no clue about the error. I will lwt you know if i can figure it out..
shanti |
February 23, 2007, 19:13 |
#10 |
Thanks. I think should use DEFINE_HEAT_FLUX to give the condition of wall flux. But I don't konw how to use DEFINE_HEAT_FLUX....
February 26, 2007, 04:25 |
#11 |
hi stepaine,
why cant you go to the require reference in the fluent documentation using index option. regarding your query for DEFINE_HEAT_FLUX, please refer section no. 4.3.8 in fluent documentation (6.2. version). |
August 5, 2015, 00:09 |
#12 |
Astio Lamar
Rep Power: 13 |
Hi!
I have the same problem when I run a case with a UDF. I receive this error: this the UDF: #include "udf.h" DEFINE_DIFFUSIVITY(mean_age_diff,c,t,i) { return C_R(c,t) * 2.88e-05 + C_MU_EFF(c,t) / 0.7; } and this is the error: ip-exec: mean_age_diff: argument 4: incorrect type (0): int expectedchip-exec: mean_age_diff: argument 3: incorrect type (5): pointer expectedchip-exec: mean_age_diff: argument 4: incorrect type (0): int expectedchip-exec: mean_age_diff: argument 3: incorrect type (5): pointer expectedchip-exec: mean_age_diff: argument 4: incorrect type (490510): int expectedchip-exec: mean_age_diff: argument 3: incorrect type (5): pointer expectedchip-exec: mean_age_diff: argument 4: incorrect type (0): int expectedchip-exec: mean_age_diff: argument 3: incorrect type (5): pointer expectedchip-exec: mean_age_diff: argument 4: incorrect type (0): int expectedchip-exec: mean_age_diff: argument 3: incorrect type (5): pointer expectedchip-exec: mean_age_diff: argument 4: incorrect type (0): int expectedchip-exec: mean_age_diff: argument 3: incorrect type (5): pointer expectedchip-exec: mean_age_diff: argument 4: incorrect type (0): int expectedchip-exec: mean_age_diff: argument 3: incorrect type (5): pointer expectedch 40047 2.4 Is there any solution to fix this? Thanks. |
User Wall Heat Flux | Dyls | STAR-CCM+ | 0 | May 13, 2013 11:58 |
UDF to calculate average heat flux | dynamics | Fluent UDF and Scheme Programming | 0 | July 21, 2012 18:54 |
heat flow UDF on coupled surface (wall-shadow wall) | Friedmann | Fluent UDF and Scheme Programming | 0 | August 5, 2010 10:25 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
